strange vibration while idling in Drive
What should I check for?
If you have long tube headers i would check to see if your y-pipe is touching the floor.
1.) Have you messed with the EGR at all?(EGR Mod)
If you have,.......then it could be the rubber ring on the EGR tube not set right(air leak). Usually that causes a pulsating vibration at idle. I know,..It happened to me 2 months ago. If you haven't,.still might want to check it out. Sometimes it happens all on its own without you touch'n it.
2.) Check all your intake seals after the MAF.(related to above) If you have a leak somewhere,....its gonna screw up your idle. This means your MAF to your Bellow seal, your Bellow to your TB seal and your TB to your Intake seal. check em and make sure that you have a good seal between em.
If those don't fix it then these could be the culprets......(be advised,.if it isn't any of the things ive listed above,....then it isn't an intake issue at all.)
3.) A misfire(check your plugs) If you use alot of octain boost back to back,.then it can screw em up. Then again,.when was the last time you swapped your plugs out? Stock ones are good for up to 100K miles according to the manual. (this doesn't mean you should follow that instruction) Sometimes plugs go bad,...quick!
4.) A bad Cat/s...... Yea,.this one,.you don't want! But this only really becomes an issue after 80K miles or so.
