Sponsored by: CARiD
Need Help Quick..Putting In new ported throttle body
Old Oct 3, 2006 | 02:37 PM
MidwayAvenue's Avatar
Default Need Help Quick..Putting In new ported throttle body
i got a new ported throttle body putting it in but i need to get the 2 bottom hose conectores off the old one and put it on the new one but they wont budge how can i get these off...and it may be getting dark soon dont have lights..to keep working
thanks for the help guys
Old Oct 3, 2006 | 02:44 PM
staringback05's Avatar
hose connectors on the tb or on the coolant tube?....do you just mean the clips on the tubes?....or the two tubes that stick out?
Old Oct 3, 2006 | 02:52 PM
the 2 metal tubes that stick out for the coolant..that'd be them..
Old Oct 3, 2006 | 02:57 PM
ya cant get them off man...there cast to the tb itself....what you can do is bypass it...take the tube from the one side get a small connector...and connect the two hoses...dremel off the two tubes that stick out...
Old Oct 3, 2006 | 03:04 PM
the other tb has a hole for something? and is that safe conecctiong the 2 hoeses?
what would you recommend to connect them
Old Oct 3, 2006 | 03:16 PM
Old Oct 3, 2006 | 03:19 PM
http://cgi.ebay.com/ebaymotors/Fireb...QQcmdZViewItem
you dont exactly have to have that....you can get the parts from home depot....this is just to give you an idea and put some pictures of it there for ya
Old Oct 3, 2006 | 04:01 PM
ah alright i see what you were saying so basically i just need to connect the two hoses and it doesnt have to go through the tb....i just decided to put the old tb back on til i get some conectors for the hoses
alright thanks for all your help man i should of done some research before i started
Old Oct 3, 2006 | 04:17 PM
anytime
Old Oct 3, 2006 | 08:43 PM
bitterchaos's Avatar
use pliers to move the clips down a couple inches and then use the pliers to wiggle the hose back and forth on the metal tubes to loosen them up. Heat makes them stick to the tubes. After that they should come off pretty easily. As for the TB bypass (connecting the tubes together), I just took out the old hoses completely since they were getting old and hard and bought 2.5 feet of Goodyear hosing from autozone and had the coolant go from the radiator all the way to the connector on the engine in 1 long tube.
Old Oct 4, 2006 | 08:31 PM
Shallow Bay's Avatar
That's a good idea, what size hose did you use?
Old Oct 19, 2006 | 09:04 PM
5/16"...it'll be a tight fit on the radiator opening but as long as you get it on there enough to put on a worm clamp you're good
Old Oct 19, 2006 | 09:38 PM
spy2520's Avatar
i think i used 3/8" hose, it was a good fit on the radiator, kinda loose on the coolant tubes near the head, nothing a clamp wont fix though...
