misfire/rough idle??
Old 10-03-2006, 11:18 PM
sping012's Avatar
Default misfire/rough idle??
I was having cylinder 2 misfire, along with a code of my O2 being fouled out. The car was shaking and it would choke and rumble when given gas. I changed the O2 and for about 3 days the car ran fine. Now the rough idle and the shaking is back? When sitting at a light it would idle rough and then seem to choke back into normal running. Could this be a plugged fuel injector? Old gas filter? Thanks guys!
Old 10-03-2006, 11:29 PM
staringback05's Avatar
you can def. check those, are you throwing any other codes, it sounds like you could either have a air leak or a failing maf....how many miles are on the car?
Old 10-03-2006, 11:56 PM
sping012's Avatar
actually there was another code but i cant remeber the exact numbers, but he mentioned something about the air intake wires? or maf wires? i have 79K on it.
Old 10-04-2006, 12:27 AM
man that would help if you could find out that info for me....esp. if the guy u were talkin to said something about maf wires....get those codes for me and check back
Old 10-04-2006, 04:17 PM
sping012's Avatar
lol, will do! Yeah i bet its pretty hard not knowing the codes!
Old 10-04-2006, 04:49 PM
sping012's Avatar
Ok, here are the codes i have
P0152
P0418
P1153
P0300
I had this rough idle and shaking for a bit, so i got a code check last week, and the front passenger 02 came up. I changed it 2 days ago, so that code may not be in effect? And the air pump is gone so that code is not in effect eithere.
Hopefully i can figure this out!
Old 10-04-2006, 08:06 PM
SSucese's Avatar
I just ended up having the exact same problems last week with those codes and rough idle and over the past weekened I found out it was my fuel pump. I hope thats not the problem with yours but you might want to check your fuel pressure on the fuel rail.
Old 10-04-2006, 08:13 PM
Shallow Bay's Avatar
DTC P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
DTC P0418 Secondary Air Injection (AIR) Pump Relay Control C
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
DTC P0300 Engine Misfire Detected
Old 10-04-2006, 10:20 PM
^^^^ air leak/bad o2s....will change alot of things in your motor, that will make it run totally different
Old 10-05-2006, 12:36 AM
sping012's Avatar
My O2's should be fine now, my car runs for about a mile after startup fine, then usually everytime around the same distance it runs hard and idles terribly rough. I have an Auto (A4) and it seems like from take off it shakes and doesnt want to switch into the next gear, but it does and then it kind of surges. Not sure if this gives any more help?
Oh and if im around 30+mph if i WOT it it seems to be ok until i let off the gas again??
This is such a pain! lol
Old 10-05-2006, 12:40 AM
geez you just keep coming up with stuff....you could have a bad tc from what you just stated there....id still like to see you put the car on efi live and see how rich it is running and what the spark tables are doing
Old 10-05-2006, 12:49 AM
sping012's Avatar
wouldn't i get a code for that? I'm changing the fuel filter this weekend for sure, and seafoaming it, then i'll see where that takes me.
I hope its not the pump.
Old 10-05-2006, 01:17 AM
you wont get a code for a bad torque converter....itll just drive like garbage...not shift right, feel like its bogging, just run bad in general....yea go ahead and knock that stuff out and check back
Old 10-05-2006, 01:14 PM
Public Enemy's Avatar
is p0152 the one in the left or the right 02? say for example your under the car from the back, cause i have the same code.
thanks
Old 10-05-2006, 01:33 PM
thanks
It's going to be the passenger side pre-cat O2 sensor.
FWIW, here's how you can tell what side/sensor it is.
Bank 1 - Driver side
Bank 2 - Passenger side
Sensor 1 - Pre-cat
Sensor 2 - Post-cat
Old 10-05-2006, 03:37 PM
sping012's Avatar
If the TC was bad, wouldnt this be a constant problem? When the car is running right (the very few times it is) it runs good, shifts nice, decent acceleration. But yeah ill get back after replacing the cheaper stuff first.
Old 10-05-2006, 10:06 PM
not always no....i still think it might be a sensor somewhere....o2s or maf or cats...
Old 10-06-2006, 07:07 PM
sping012's Avatar
Well, i changed the fuel filter today, and the car runs like new! The fuel filter is the STOCK fuel filter on an 80,000 mile car!
I thought it was changed by the previous owner! Whew, and the pump works fine, so thats not a problem eithere, new O2's i got them rescanned today and no Codes came up. So i think its solved!
Old 10-06-2006, 07:21 PM
CASHss99's Avatar
i have the same problem. the passenger side plugs all fouled and the front 02 same side. i changed the fuel filter nothing changed. i have the same symptoms as you, rough idle while at a light you can feel through the seat. i can rev it a bit and it will shake the steering wheel and kar. i have tr6s gapped at 45 which kept the p0300 code off for 5 months now. but i have the same symptoms as you minus any codes popping up... runs rough enough to pop a code but it doesnt. any help
Old 10-06-2006, 07:23 PM
CASHss99's Avatar
im thinking its the taylor wires or since i changed the fuel filter teh tr6s are making it ****. maybe its time to go back to AC DELCO PLUGS
Quick Reply: misfire/rough idle??
