Sponsored by: CARiD
Very bad noise!
Old Nov 4, 2006 | 01:41 AM
97camarozguy's Avatar
Default Very bad noise!
Ok, i was going to get on it at a corner on my way home and i herd this horrible bang. I felt it come up through the shifter and my whole consol shook. I have a 97 z28 auto. Anybody know what this could be? It scared the ever living hell out of me!
Old Nov 4, 2006 | 02:04 AM
staringback05's Avatar
gotta gimme more then this...you could have just hit something....drive the car more see if it does it again and has any other noises or problems
Old Nov 4, 2006 | 09:19 AM
Sorry, when i was coming home, i got on it and it made the bad banging noise. When i pulled over i could smell something burning and it wasn't tires. When i left i went up through all the gears and every thing seemed ok. It still drives alright, its just everytime you try to take off remotely fast, it will make that noise and you can feel it in the shifter and in the whole console. My buddy who is a mechanic said it could possible be the tourque arm. Does that sound right? I am not a mechanic by any means.
Old Nov 4, 2006 | 09:33 AM
98 Raptor TA's Avatar
it sounds like your tranny mount. My auto i used to have did that once. The transmission jumps up and can hit the transmission tunnel when the mount is broken, that's why the banging comes from right under the console. And it only bangs when you punch it, you can drive around like a grandma and it wont act up.
Old Nov 4, 2006 | 10:16 AM
bigfoot2thefloor's Avatar
wheres my dog?
Old Nov 4, 2006 | 10:57 AM
is a tranny mount easier so replace than an engine mount? I had a buddy look at the engine while i slowly eased into it and the back of the engine started to raise up quite a bit. Is ther eany heavy labor in replacing the tranny mount? You don't have to pull anything off do you?
Old Nov 4, 2006 | 11:32 AM
desertLS1's Avatar
cake>>>>> should take like 10 min tops! just get under it!
Old Nov 4, 2006 | 11:46 AM
98boxer's Avatar
Its simple to change the tranny mount, but for a do it yourself project, it took me about an 1 hour or a little less.
Old Nov 4, 2006 | 01:55 PM
DOUBT IT's Avatar
I change tranny mounts with my hands tied behind my back... in my sleep... in ten minutes or less.
Seriously though, just put the car up on jackstands or ramps, put a block of wood on top of your jack, raise the tranny slightly. Unbolt the crossmember, unbolt the mount, replace mount with Energy Suspension. Reverse procedure.
Pat yourself on the back for a job well done...
Old Nov 4, 2006 | 02:04 PM
blk97z28's Avatar
Default yep that the tranny
yes mine broke while i was racing a 2003 gt 5 spd it made that same noise i did mine in 25 min i think! very easy
Old Nov 4, 2006 | 05:43 PM
I just hope i didn't break any engine mounts. is that a likely possibility? How much does a new mount cost?
Old Nov 4, 2006 | 10:18 PM
bradmb's Avatar
dude, i promise you its the tranny mount. i have had to replace mine too. on a load it can grind and shake and when it shifts it pops loud as crap. i had mine replaced at a shop, and it wasnt too bad. i tend to remember the exspesive repairs and i cannot recall this one.
i would have done this myself, but i work 40 hours a week and go to FSU full time. so paying a shop makes more sense sometimes.
Old Nov 4, 2006 | 10:20 PM
blk97z28's Avatar
not bad at all!
blk97z28's Avatar
i did my own and i am only 17
Old Nov 4, 2006 | 10:37 PM
JT LS1's Avatar
I think he was asking if it were possible if he could have also broken an engine mount due to the tranny mount being broken.
To answer your question 97camarozguy, I doubt it.
Old Nov 5, 2006 | 03:17 AM
ok, thats good. Yes i was asking if i could have also broken the motor mount. Should i go to a salvage yard to get a tranny mount or should i just buy new? How much are these if i were to buy new?
Old Nov 5, 2006 | 10:13 AM
DO NOT GET A JUNKYARD TRANNY MOUNT LOL
Old Nov 5, 2006 | 11:44 AM
any idea on what a new one would cost, I can't imagine them being too expensive.
Old Nov 6, 2006 | 12:28 AM
DOUBT IT's Avatar
Any local auto parts house should have them or be able to get them for $35 to $50. I think that I paid $45 for my Energy Suspension at the local speed shop. Haven't broken that one... yet.
Old Nov 6, 2006 | 08:02 AM
spy2520's Avatar
i bought mine for $20 off byunspeed, but i think autozone carries them for not much more, it is the same mount for 1958-up GM trannies. i replaced mine for the first time, took little more than 20 minutes to do on jackstands...
