I F&%$#ING HATE TRANS AM HEADLIGHTS!
Ok, as some may know, especially blackduk98, I have been having tons of problems with my headlights. The gear was stripped on the passenger side, I replaced the gear, worked for a few days, then acted up again. Then it got real bad, headlight wouldn't move, it just flipped up and down uncontrollably. So I finally replaced the whole motor, 140 bucks worth. Then today, my headlight is stuck up! So I manually put the driver side light up to see how that looked, and saw a bolt on the broken passenger side should be flipped around. I did that and the headlight worked again, but when I put my headlights down by the switch, the driver side headlight began to make the same noise when my passenger headlight gear got stripped! It worked fine until I manually put it up, could it strip out just from manually putting the light up? WTF is up with these lights? GM is retarded for making such a shitty design! Now I am going to have to dump another 140 bucks on another head light? What else can I do? Push my car off a cliff?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I know about the brass ones, I didn't have the money at the time and ordered plastic ones. But I've seen people strip out the brass ones. When I did the gear install, something went wrong, and instead of making a grinding noise when it goes down, it did when it went up and then eventually the motor wouldn't hold the light in place. But I got a new motor for the other side, so total with parts, tools other gears etc I've spent over 300 bucks! But I have two new motors and working headlights again, hopefully for another 80k miles. Thanks.
As jd amg said ,the motor comes loose from the plastic head.Brent Franker,the guy that makes the brass gears,shows pics on his website and says that even the brass gears will FAIL if you neglect to check for this condititon.He has sold over a thousand brass gears and has a lot of feedback.You should read his research very carefully as any headlight problem ,he feels, can be attributed to this.I presume a new motor may loosen in time or maybe just from handling too much.Holding parts together by bending tabs over is a **** design,for sure.
I wonder if putting a good epoxy over each of the tabs and letting it run down over the edge there a little would serve as a good reinforcement. You'd probably never get it apart again, but maybe it'd help keep the tabs from separating.
Ok I must be a genius because i am the only person that I know that did this and it works like a ******* charm. Try this out man:
Buy the brass gears and then go to home depot and buy 4 of the very small C-Clamps that they have. Now when you install the brass bears and then epoxy the case together, place 2 C-clamps on each motor and crank them down fairly tight and then cut the handle part of the clamp that you turn off so that it allows you more room for the re-install. Then install the motors again. The epoxy combined with 2 c-clamps on each case will hold forever and you will never have to worry about stripping a gear or splitting the case again.
Originally Posted by Trust
You need to be sure to let the motor housing seal and cure properly, if not, even the brass gears will strip from it popping open. Honestly I'd just bite the bullet and buy another motor and not deal with it for another 50k
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by taintedmeat
That won't keep the metal tabs from loosening/bending over time.
Havent had a problem since. My concern was keeping the case intact because that can cause even the brass gear to strip.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![](http://i6.photobucket.com/albums/y209/federalbeerinspector/gears003.jpg)
How did that happen? You were pretty unlucky huh?
I guess the tabs were a little lose. I had to break the thing apart to get that brass gear out after it stripped.
So there are two main problems, even before a rebuild:
1:loose tabs=stripped gears(brass OR plastic)
2:loose case after gluing=stripped gears(brass OR plastic)
That about sums it up!
