Sponsored by: CARiD
BRAKE light keeps coming on???
Old Nov 14, 2006 | 09:25 AM
HowellSoccer88's Avatar
Default BRAKE light keeps coming on???
My BRAKE light keeps coming on for some reason and Im not quite sure why...the last thing I did on my car was the wire mod but I am positive everything is hooked back up right because Ive double checked. It doesnt come on right when I start the car but after a little bit of driving it pops up. Any ideas? Thanks in advance!
Old Nov 14, 2006 | 11:08 AM
2001whiteSS6spd's Avatar
Make sure your master cylinder is to the full line with brake fluid. And if your brake fluid is low enough to set off the light you should check your brake pad thickness, it may be time for new brakes.
Old Nov 14, 2006 | 12:58 PM
The car only has 41K on the clock...do you think it would be time for new brakes this early?
Old Nov 14, 2006 | 01:06 PM
jmm98LS1's Avatar
The red BRAKE indicator light on the dash cluster has nothing to do with your normal braking system----it's for the parking brake. Check to ensure your parking brake handle is all the way down. The switch is located under the center console....might be shorting out if the lamp is still on while the parking brake is fully released.
Old Nov 14, 2006 | 01:55 PM
Well yea I know for sure the brake handle is all the way down...assuming something was shorting out what do you recommend?
Old Nov 14, 2006 | 02:13 PM
jmm98LS1's Avatar
You can pull the top section of the console off and check to see if you can trip the switch to make the light go off and begin your troubleshooting from there. The switch might be bad, it might have moved enough to not be engaged with the lever all the way down, etc.
Old Nov 14, 2006 | 02:18 PM
I agree with most everything your saying. But the brake indicator light will come on if the brake fluid in the master cyliner is low. Which is also an indicator that your brake pad thickness is getting low also. So this is the first thing I would check.
Old Nov 14, 2006 | 07:00 PM
Tainted's Avatar
i got the same problem only it stays on all the time. so what does the switch look like? do you need tot ake uot the entire lower console or is there an easier way to trip it?
