what motor mounts?
I'm all for adding stiffer bushings to suspension, but like to stay away from installing for tranny or motor mounts unless absolutely necessary...
I can see if you're cranking out 800RWHP but at anything under 500, why go to all the trouble of changing them out if the stock mounts are still good?
Seems like pretty much a waste of time...
i bought prothane motormounts and a prothane tranny mount and an energy suspension torque arm mount all from summit for 89.xx shipped.
Keeps the motor in its place, helps reduce chassis flex, alot more straight line acceleration,
My header was rubbing steering shaft after the header change. plus its the torque side. As far as trans mount goes, under acceleration the gearshift doesnt move as much. Plus my trans, engine and torque arm mounts were shot anyways.
