cyl 4 missfire
Wires will vary depending on brand. The MSDs will be about 20-30 ohms, while the stock wires are more like 300-350 ohms.
There's a special gage/tool that you'll need. When you test the cylinder, you want it to be at TDC for best results. The double-gaged tool will plug into the spark plug hole much like a compression tester. You'll need this tool plus an air compressor. You will be forcing compressed air into the cylinder, and you can regulate the amount of air with the tool. One gage will measure the amount of air you're forcing into the cylinder, and the other will measure the amount of air that is being lost (in percentage format). While doing the test, you'll be listening for where (if anywhere) air is leaking out. Listen in the following areas:
Air leaking back through the intake: intake valve issue
Tailpipe/exhaust leaking air: exhaust valve issue
Air leaking out of open oil fill cap: ring issue
Could also be a head gasket if none of those produce results, but the gage still shows a pressure loss.
However I doubt your issue is related to rings or a head gasket, unless you have other symptoms like oil/coolant mix or massive oil usage. Plus if you have ticking/tapping it points more towards a valvetrain issue than gaskets/rings.
The only one I've ever seen belonged to my buddy with a local repair shop. His was from MAC tools. I'm sure all the big name automotive tool brands sell one though....
