Sponsored by: CARiD
Rear Defrost?
Old Dec 2, 2006 | 01:01 PM
Splitz's Avatar
Default Rear Defrost?
ok, yes, Texas weather is weird. Had freezing sleet/snow/rain the other day, so I had to use the rear defrost, ummm....didn't work. What should I look at first?
Old Dec 2, 2006 | 01:07 PM
2002_B4C's Avatar
Fuse? is the defrost light coming on, on the swithch button?
Old Dec 2, 2006 | 01:12 PM
Splitz's Avatar
light comes on, couldn't be the fuse right?
Old Dec 2, 2006 | 01:19 PM
2002_B4C's Avatar
Not sure? don't have a schematic in front of me. I dont think its actually a colored type fuse, its one of the silver "breakers" they call them, if I remember correctly. They're not known for going out, but you never know. Also check the wires that actually plug into the window. Sometimes the plastic plugs get bumped or broken, lift up the hatch and you will see them. Hope this helps. PS- while you got the hatch open, throw a bottle of nitrous in there!
Old Dec 2, 2006 | 01:23 PM
Splitz's Avatar
yea, stupid defrost, I'll probablly look at it later. Thanks for the suggestions!!
not really looking at NOS. I was thinkin' maybe turbo @ 10psi... building saving account and doing te entire car at the same time.
Old Dec 2, 2006 | 08:11 PM
98LS-WON's Avatar
Turn on the rear defrost and try to adjust your drivers seat(if it's electric). If it doesn't work, replace the silver breaker with a 30 amp fuse and that wll fix it.
Old Dec 2, 2006 | 08:57 PM
Splitz's Avatar
thanks 98LS-WON...I'll try that out in the morning, I knew that the drivers seat/rear defrost was on the same breaker
Old Dec 2, 2006 | 10:41 PM
ChocoTaco369's Avatar
Tech Resident
just a thought, but since the light comes on, perhaps your rear defrost is weak. my rear defrost IS TERRIBLE! the rear defrost on my old V6 '95 firebird was AWESOME. it would melt ice in 2 minutes. the rear defrost on my '01 formula is HORRIBLE. it barely works. after running for the full 5 minutes or whatever, it takes half an inch lines out of FOG. it's soooo weak perhaps you are having the same problem. it's on, it's working, it's just pathetic. anyone know how to go about fixing this
Old Dec 2, 2006 | 10:59 PM
sixvi6-camaro's Avatar
Yup.. both the 95 4th gen cars I had in the past as Wicked rear defogger. you could probably cook on egg on that defogger but.. the LS1 car I have now is a joke! It struggles to get fog off the glass and frost.. forget about it.
Old Dec 2, 2006 | 11:24 PM
rayvendawn's Avatar
I live out in arlington,tx... anyway mine doesn't work either, but its because the little thing broke off of my window and now a cord is just dangling. I'm not sure how to get it back on.
Old Dec 6, 2006 | 12:37 PM
pjb's Avatar
pjb
98lswon is correct. if it comes on for about a minute and goes off, the breaker is overheating. it takes 5-10 minutes for it to cool down and be functional again. during this time the power seat won't move either. replace the breaker as suggested above and the problem will be solved.
Old Dec 6, 2006 | 01:52 PM
noname024's Avatar
Not to hijack this thread or anything...but thanks a ton! I've been wondering about how to fix this for the longest time now. But when you say breaker what do you mean? The original fuse for the defrost?
Old Dec 6, 2006 | 01:57 PM
pjb's Avatar
pjb
the original is a silver breaker, not a fuse. If you pull the breaker out and insert a spade type fuse (like the rest of your fuses) with the correct amp rating (I think 30 amp is correct) your problem will be solved. I lived with it for a couple of years before I found this fix and have not had a problem since.
Old Dec 6, 2006 | 02:08 PM
Abidar's Avatar
Scrape off the ice...
When I got the car tinted if I remember correctly, the guy told me not to turn on the rear defrost so I have done without for a while. Scraper and a window open will do wonders...
Old Dec 6, 2006 | 02:09 PM
noname024's Avatar
Thanks! I'm tired of living with it too. Gonna go change that bitch now.
Edit: Just an update. Just did this and defrost works like a charm now.
Thanks again.
Old Dec 6, 2006 | 03:38 PM
09CPTN's Avatar
Sounds like BS to me. Defroster shouldn't hurt your tint. I have tint on my car and I use the defroster regularly with no problems.
Old Dec 6, 2006 | 08:25 PM
2002_B4C's Avatar
See, when you ask enough people, some unlucky bastard has had the same problem. Good job guys!!!!
Old Dec 9, 2006 | 02:12 PM
oifish's Avatar
So if I replace the breaker with a 30amp fuse will the defrost turn off after a while like it normally would with a breaker? Or will the defrost stay on until the fuse blows?
Old Dec 9, 2006 | 08:31 PM
Farmer2's Avatar
I had this same problem. I replaced the resetable breaker with others and they would trip too. I put the 30 amp fuse in and have never had any other problems again. I checked the hot wire to the defrost grid and it was no where near the tripping amps. Try the fuse and have soemone with a amp probe double check the draw for you.
Old Dec 10, 2006 | 08:40 AM
oifish's Avatar
alright ill go with the fuse, it seems that its perfectly fine. If anything does goes bad the fuse will just blow, no harm there.
