battery vampire
Going with the theroy that you jumped it and let it idle and charge, possibly drive it around it should be fine.
My thought is that you have a draw some where in the car.
Take off the negative cable and tap the battery terminal, it should give a good spark, mind you that you will get a lil one due to the PCM but if there is something on, its gonna spark. Also listen for any clicks.
In my particular case, the prev owner directly wired a accessory from a 12 volt constant, the cigarette lighter and it got tied into a relay and had a constant draw, no matter what I did, if it sat more then 3 days it wouldnt start. I had to track it down.
