Sponsored by: CARiD
Spark plug problem
Old Dec 28, 2006 | 12:47 AM
vMaster0fPuppets's Avatar
Default Spark plug problem
I don't know if this is normal, and did a search that returned no information.
First, some backround. I have TR-6 plugs, MSD wires, longtubes, and the engine is completely stock.
I was under the car attempting to track down a ticking sound. It seems like it coming from the block of the engine. It is definetly on the passenger side of the engine, and loudest from under the car. It is loudest from underneath the passenger door, and louder from underneath the driver's door than when standing over the engine.
ANyway, I noticed that the 2nd plug back on the passenger side of the car seems to stick out a little. It is the only plug I can still see some white of that is not hidden by the wire and engine. I tightened it all the way, and pressed the wire on as far as it will go and still it seems to stick out.
Is this normal? What could this mean? As a side note, what could the tickl be?
Old Dec 28, 2006 | 10:40 AM
HandsomeBWouderful's Avatar
The tick is most likely exhaust escaping through the threads in the plug since the plug is not all the way in. The same thing happened to me. One of my plugs did not want to screw all the way down. I think the treads may have had a burr in them or were slightly damaged when I took the plug out. I ended up having to clean out the treads and retap the hole, then the plug when all the way in.
Old Dec 28, 2006 | 04:31 PM
Mohammed's Avatar
does it sound like a sewing machine ??
Old Dec 30, 2006 | 12:19 AM
Zoegirl's Avatar
Your right, it may be an exhaust leak then.
Old Dec 30, 2006 | 09:56 PM
DRSITES's Avatar
You sure it's not the ol' LS1 lifter-tap?
Old Jan 2, 2007 | 02:52 PM
I don't really know how to identify the sound. It actually seems to sound different depending on where you stand around the car. Theres a tick from most places, but what sounds like a knock from certain angles. But, I guess it has a resemblence of the sound a sewing machine makes...
I'm not sure what the lifter tap is? I heard about it, and changed to German Castrol which seemed to have had no effect on the sound.
I'm going to attempt just preplacing the spark plug, I really hope I don;t have to tap a hole in the engin, because theres just no room.
Old Jan 2, 2007 | 03:45 PM
JAvenger007's Avatar
Check your air pump gaskets. If theyre broken or missing then the car will make a ticking sound under load. Also make sure your wires/plugs are snug. If all of that is good then its likely just the common lifter tick that ls1's make. Its normal for the valve train to sound like a sewing machine.
Old Jan 3, 2007 | 06:50 PM
I removed my air system after i installed my longtubes. I'm not sure if i removed it entirely, how do i check to make sure. I follwed the instructions on install universdity i believe.
Old Jan 3, 2007 | 09:36 PM
blackbirdls1's Avatar
Loose plug or wire will cause this. For some reason a few months back during my spark plug install, one seemed to be loose. I must of not tightened it properly, which caused a ticking sound and loss of power. I rechecked all the plugs and ended up with one loose one.
Old Jan 4, 2007 | 03:37 PM
just replaced the plug, and the tick seems to be gone. yay
