Sponsored by: CARiD
Fuel Filter location on a 99 TA
Old Jan 11, 2007 | 12:15 PM
CubanGT's Avatar
Default Fuel Filter location on a 99 TA
Trying to help my girl out and save some money... where is the fuel filter located on a 99TA so i can replace it for under $10 versus paying Almost $30 to have it installed by someone else.
Thanks
Old Jan 11, 2007 | 12:28 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Driver's side of the car. Get on the ground between the back of the door and the front of the tire. Look up where the frame rail is. Fliter will be right there, in the fuel line.
16mm and 20mm wrenches are needed to change out the filter.
Old Jan 11, 2007 | 01:32 PM
CubanGT's Avatar
thanks... i went ahead and got the fuel filter for $8...
Old Jan 12, 2007 | 07:33 AM
gonefishn1212's Avatar
its a very easy prosess to change out that filter, just need a little muscle to get it out.... from my own experience. located driver side door and fwd of left rear tire.... youll see the metal fuel line and just follow it till you come to the metal bulge... that would be yout fuel filter. go with the napa gold filter its like 7-8 bucks, i personally havent had any problems with it....
and its good to change them every 10,000-15,000 miles
Old Jan 13, 2007 | 06:06 PM
ROB2000's Avatar
do you know if its same size for 94 t/a as well?
Old Jan 13, 2007 | 06:45 PM
RPM WS6's Avatar
Should be 16mm and 20mm.....otherwise, I beleive the equivalent standard sizes are 5/8" and 13/16". Gotta be one of those.
Old Jan 13, 2007 | 07:15 PM
TXZ28LS1's Avatar
hey guys do u just have to just take the old one off and put one on? or did u have to do other stuff like, open the gas cap, unplug the fuse and other stuff like that?
Old Jan 13, 2007 | 09:14 PM
MEZA TA's Avatar
You can just swap it....however be aware that you will spray some gas once you open up either end of the filter but don't be alarmed..it's normal. Just don't lie on your back looking straight up to it because gas doesn't taste good. HaHa
Old Jan 13, 2007 | 09:36 PM
RPM WS6's Avatar
Exactly.
Old Jan 15, 2007 | 08:04 PM
ROB2000's Avatar
thank you, gonna change it this weekend.
