Sponsored by: CARiD
Engine Knock/Tick . . . What could it be?
Old Feb 18, 2007 | 03:58 AM
02TransAm/Batmobile's Avatar
Default Engine Knock/Tick . . . What could it be?
i've heard a slight knockin about a month ago and now its getting a lot worse. I was on my way to my ladies house tonight and said, "forget this", drove back home and took the envoy. It sounds really bad (in my opinion) . . . i noticed before that it usually happens when i have around 35 psi of oil at idle, . . at 40 and up on idle, the noise is not there. . tonight's knocking was the worst it has sounded, really clear, loud tapping and the ticking rolls faster with revs, . . . its 3:57 in the mornin so don't flame if my thread sounds like a 5 year old girl wrote this, . . im tired
thanx
Old Feb 18, 2007 | 05:32 AM
ss292355's Avatar
it could be piston slap.also have you changed your plugs resently.they could be loose .happened to me
Old Feb 18, 2007 | 05:52 AM
staringback05's Avatar
how many miles does your car have on it? and are the internal lower end parts stock?
Old Feb 18, 2007 | 10:46 AM
Razor_Blade's Avatar
I would check the easy stuff first.
1) Exhaust leaks
2) Loose rocker arms
3) Loose spark plugs
4) Cracked or damaged balancer
You can also probe the engine with a mechanics stethascope.
Another old school trick to locate engine noises, was to cut a piece of broom stick about 24'' long and hold one end to your ear while touching various places on the running engine with the other end.
Old Feb 18, 2007 | 01:37 PM
33k on the clock, all stock internal and bottom end, . i've tried holding a metal rod while tryin to locate the source and i can not find it, . . haven't touched the spark plugs recently and it doesn't sound like an exhaust leak because my mechanic had it up and the sound was coming from the internals
Old Feb 18, 2007 | 03:46 PM
01WS6/tamu's Avatar
possibly a rod bearing
Old Feb 18, 2007 | 05:04 PM
used a ghetto stethescope and the ticking is coming from the passenger cylinder head, .. don't know if its actually in the cylinder head or combustion chamber . .
Old Feb 18, 2007 | 06:26 PM
01WS6er's Avatar
to check for internal rod bearing damage.
Loosen all plug wires. Crank engine until operation to where the noise is the loudest/constant. One at a time remove the wire off the plug. If the noise is still there than reinstall the wire. If you remove the wire from a cylinder and the noise goes away/quietens down then you have a rod/piston problem. If you go thru this procedure and the noise is still there than you may have other problem. I have done this procedure on multiple engine to determine if it is bottom end of top end noise. Try and see what you find out.
Removing the fire off the rod/piston assy relieves the pressure off the bearing. that makes the rod/piston assy just float on the crank. Since it is floating it will not produce the loud knocking noise.
Since you have narrowed it down to the pass side than just do that side. That will save you lots of time.
Old Feb 19, 2007 | 04:46 AM
piston wrist pin.....FTMFW
Old Feb 19, 2007 | 12:43 PM
J. Brown's Avatar
bent push-rod.
Old Feb 21, 2007 | 03:50 PM
what? so turn the engine on and remove the spark plugs one by one? call me a noob, but isn't that toyin with the engine?
James
More info, . . noise is still there, . it does not go away when warmed up like some people have told me, (locals). Imma take the damn thing to the dealer . . but i'll try that spark plug routine if anyone can verify that information.
Old Feb 21, 2007 | 05:28 PM
another update:
we finally hit 40 or so degrees outside, .. i took the car around the block and now i have around 20 PSI of oil pressure at operating temperature and 800 idle, . . i think i need a new oil pump
Old Feb 22, 2007 | 05:45 AM
Spun Bearing.............
