best oil
I prefer M1 0W40 though. Much easier to find, and also a good choice for an LS1.
But seriously if you just keep your oil clean and changed often you should have many happy driving miles. I used to use Mobil1 in my Tahoe and it seemed to like it. But it seemed to like dino oil too. Soooo??
When I first picked up my TA I was out of state and needed an oil change asap. I went to the first Jiffy Lube place I could find (honestly the first time I had been to a place like that in my life) and had it changed with regular oil. I ran it 3000 miles just fine.
Last oil change I tried this German Casrol 0w-30 everyone raves about here. I dunno, I didn't notice any difference?
I would say that oil change interval is more important than which brand or level you use.
ive built and raced cars for over 10 years.these engines have very loose clearances from gm.
http://www.mobil.com/USA-English/Lub...il_1_0W-40.asp
And here are the specs on Mobil 1 10W30 (for comparasion sake):
http://www.mobil.com/USA-English/Lub...l_1_10W-30.asp
For 0W40:
cSt @ 40º C = 80
cSt @ 100º C = 14.3
For 10W30:
cSt @ 40º C = 62
cSt @ 100º C = 10.0
In other words, M1 0W40 is a thicker oil than 10W30 at both cool and warm temps. Just because it's rated as an 0w at cold start does NOT mean that it's a thinner oil than a 10w. If you look at the specs for both, M1 0W40 is thicker than M1 10W30 at 40c, so on a cold start in the spring/summer/fall temps, the 0W40 is actually thicker. What happens as you get into extremely cold temps, is the 0W40 has better cold cranking performance than the 10W30, and is thinner at that point. But during normal temps it's actually thicker, and it's also much thicker as things heat up as seen by the specs at 100c.
In addition, I have slightly higher oil pressure readings using 0W40 over 10W30, and my LS1 burns ZERO oil with the 0W40. And yes, the car does see WOT action.
So please, do not tell people that M1 0W40 is a "thin" oil compared to 10W30s, because that statement is false. Try looking up the specs on Castrol 10W30 and see what is listed for the cSt @40c & 100c, then compare to the M1 0W40 for your own referance.
But I'm happy with the M1 0W40, plus that one is easier for me to find locally.
GC 0w30 helps with the LS1 tick a little. i used it, i still have a little tick, but no where near what i had when using M1 5w30. and like the other guy said, it must say 'made in germany'. what the differance is, i dont know, but thats what you need. WS6Store cares cases of GC 0w30 for sale, $50 per case with shipping, i think. thats quite a bit more expensive then in the store, but if you dont have any auto zones withing 50 miles of you, then its worth it. theres at least 5 AZs within 10mi. of me, so i can stock up when needed.
I tried the GC 0w-30 and actually had a louder valvetrain than when i used RP 5w-30. With the RP, my oil pressure is a steady 50psi when the engine is warm, it was closer to 40psi with GC.
However, i didnt burn any oil in 4000 milesusing GC, and i dont burn any oil when i use RP. IMO, they are both good oils but i prefer the higher oil pressure, it seems "safer". The only bad is paying 7(RP) bucks per quart versus 5(GC).
If you try the GC, most autozones carry it, it says "European formula" on the front and Made in Germany on the back.
If you choose to be ignorant to the facts, that is your option. Hopefully others will investigate for themselves, look at the facts I've posted, and make an informed decision.
PS. IMO, you are the "newbie" here.
The 0w only means that in extremely cold temps, the oil will be thinner on a cold start and flow better than a 5w or 10w. The 0w does not mean that it's a thinner oil in normal operating temps. Remember, at temp this is a 40w oil.
