Drivers side turn signal stays lit, not the bulb
If I remember correctly you'll have to pull the carpet back a little, just enough to access the plastic wing nuts. Remove those, remove the taillights and you now have access to the bulbs. Turn your turn signal indicator to the driver's side and see what bulb stays lit. Replace that one.
Copy & Paste Moderator
Originally Posted by VIP1
Check out the sticky:
https://ls1tech.com/forums/showpost....18&postcount=7
Thanks! Checked the bulb and it's good. Buddy thinks it's the flasher, checking that out Sunday. Does Autozone also carry the flashers for our cars?
Am I getting this right?
* All the bulbs flash properly with the Hazard Flasher
* Only the left signal fails with the signal flasher
* The right signal works correctly with the signal flasher.
That doesn't make sense.
Try swapping the bulbs left/right to see if the problem follows. While you are at it, inspect the sockets.
Will do but yes that is what is happening. The drivers side front does not flash with turn signal. Passenger side does. However when the hazards are on ALL 4 flas properly, also the drivers side works as a daytime driving. IT is always lit but it won't flash when turn signal is activated. Trust me this is what happens, I don't want this problem, but I have it
