water pump questions
Once you've replaced the water pump. Pour in the 50/50 mixture of antifreeze/water. Once the radiator is full (if you have access to a radiator pressure tester) you can remove the overflow hose from the overflow tank. (Tank side not radiator) Hold your thumb or finger over the end of the hose and pressurize the system. Then release system pressure by removing your finger/thumb from end of overflow hose, and drain extra coolant into reusable container. Once the pressure is down. Remove pressure tester from radiator and pour in extra coolant from reusable container, and repeat until no air is released through overflow hose.
This causes the air in the system to be forced out the highest point in the system, the overflow hose (next to radiator cap.) Haven't had any problems doing it this way.
Chad
