where to jack and place jack stands?
Old 08-07-2007, 07:52 PM
johnson7454's Avatar
Default where to jack and place jack stands?
As the title says...Where is the best place to left the car with a jack and place the jack stands? Iam as worried that the weight will warp the body a little.... Pics would be great......
Old 08-07-2007, 07:57 PM
2000Z28ls1's Avatar
I always do mine jackstands on the axels but it ussualy isnt for more than a few hours
Old 08-07-2007, 08:00 PM
what about the front?
Old 08-07-2007, 08:07 PM
ErikElvis's Avatar
On the front I use the K member. I tried on the front "frame" rails behind the wheels and didnt like the strain it seemed to put on the front end.
Old 08-07-2007, 08:20 PM
WS6NIGHTMARE's Avatar
The jacking points will work just fine, just dont leave the car jacked in one corner for 2 days. I always do as already stated, the whole front, or the whole back is coming up when I work on mine. Jack it up at the axle, or the k-member.
Old 09-23-2007, 04:18 PM
Tram's Avatar
How would you guys place the jackstands if the car was going to be on them for a week or two?
Old 09-23-2007, 06:38 PM
jond99's Avatar
I've had my car up off the ground for about a week and i placed the jackstands on all four corners of my sf's. Seemed to work great, but w/o the sfc's just go 2 on the rear axle and 2 on the k-member.
Old 09-23-2007, 08:00 PM
sf's? went blank! whats that?
Old 09-23-2007, 08:08 PM
Z28LS1camaroguy's Avatar
sub frame, there are jacking points on all cars and usually on the pinch welds. then from there just place the jack stands on the k member or where ever is strong enough to support it, i usually use the big bolts on the k member to place the jack stands.
Old 09-23-2007, 09:14 PM
ReFtheMC's Avatar
I use the frame "rails" for the front but from reading this, i think ima start using the K member
Old 09-23-2007, 09:15 PM
Tram's Avatar
Yeh, I think I'm going to use the K-member and the axle..
Old 09-24-2007, 11:58 AM
Desert Rat's Avatar
That's far and away the best. I have no trouble lifting the car by the front K member under the pan with my floor jack. It's plenty strong and distributes forces evenly across the body and causes no issues there.
Old 09-24-2007, 12:06 PM
Tram's Avatar
Yeh, I need to make sure I know exactly what the K-Member is.. I feel like the consumate newb saying that, but I just need to make sure I am putting the jacks on it..
It shouldn't have to sit up there long, maybe 2 weeks max..
Old 09-25-2007, 05:14 PM
1Loudz28's Avatar
installuniversity has a good descriptive write up
Old 09-26-2007, 10:53 AM
5301113's Avatar
www.installuniversity.com and they have pics
Old 09-26-2007, 02:26 PM
71velle's Avatar
guys with jackstands under the cars how wise is it to let it sit for a long period of time like 2 months there would be no motor or tranny so most of the weight up front would be gone
Old 09-26-2007, 06:55 PM
as long as you have the jackstands in good spots, you can leave it up there for awhile. just make sure they are in secure spots.
Old 09-26-2007, 10:25 PM
ErikElvis's Avatar
71velle. If you have the engine/tranny out of it that will take a good bit of the stress off the front end. On the front frame rails it should be fine. But by far the best spot is the k member. I dont know what you plan on doin with the engine but if its possible Id bolt the kmember back up in there if the cars gonna be outta comission for a while.
Old 09-27-2007, 03:30 AM
71velle's Avatar
well honestly i was planning up until January im doing full motor rebuild so im not positive depends on how long maching takes and how long parts take thanks for the advice on the k member idea ill probally do it if it keeps stress off the car
Old 09-28-2007, 07:08 PM
motownZ's Avatar
when jacking up one side to put jack stand under, will that make exterior body panels flex or bend, till i jack the other side up.
just not sure bc i dont trust having my front left 2 feet in the air
Quick Reply: where to jack and place jack stands?
