Sponsored by: CARiD
driver's side window not working?
Old Aug 9, 2007 | 12:58 PM
eLTwerker's Avatar
Default driver's side window not working?
I've seen stuff about GMs windows motors sucking, but the bastard search isn't working, so here goes: My driver's side window won't go up or down unless I seriously **** w/ it( pressing the button 8 million times, turning the car on/off, repeatedly opening/shutting the door, etc..) The power locks and passenger window are fine, it's just the driver's side. Is it the motor or just maybe a wire or something? Are both windows on the same fuse? Is the windows motor repairable? Where could I find a new one if it's broken and how much do they cost? Someone point me in the right direction, please. Thanks.
Old Aug 9, 2007 | 01:09 PM
sroach20's Avatar
its most likely shot, go to your local auto parts store and get one. try to find siemens, do not use that dorman crap.
Old Aug 9, 2007 | 02:54 PM
eLTwerker's Avatar
Pep boys want to charge me $80 just to look at it plus labor and the part($80). Does this sound reasonable?
Also, is the motor connected to the regulator? A local shop quoted me around $50 extra if they have to drill the regulator out of the door(if the windows motor has never been replaced before)?
Old Aug 9, 2007 | 03:19 PM
2001NBMZ28's Avatar
Get one with a lifetime warranty and replace it yourself...might even find it's been replaced before and won't have to drill the rivets. http://shbox.com/page/windowmotor.html
Old Aug 10, 2007 | 01:30 PM
eLTwerker's Avatar
Well, the window works fine so far today. The motor growls as the window goes up or down. The passenger window does not make any noise, but moves slower than the driver's side. This happened to my 02 camaro too. Had these same problems one day, then it never happened again. Maybe I'll get lucky. Anyone else's windows not work one day then start working again? How long did they continue working for?
Old Aug 10, 2007 | 01:42 PM
sroach20's Avatar
ive had them periodically cut out, then it started happening more often. then the driver side just wouldnt work anymore.
Old Aug 10, 2007 | 02:29 PM
eLTwerker's Avatar
did you change it out yourself or have a shop do it?
Old Aug 12, 2007 | 05:01 PM
GXPPOWER's Avatar
go to advance auto. thats where i went. got a motor with lifetime warranty. their is a link to a site showing how to do it yourself. its simle. the toughest part is just position the drill bit where the rivets are. i am by no means a mechanic. i can do tires/ change oil and other minor stuff. i did this by myself worked first time.
i think i paid 70 bucks for the motor?
