Seafoamed my truck if you are on the fence DO IT!!!
Old 02-07-2008, 09:19 PM
SparkyJJO's Avatar
I seafoamed my camaro at 105K (though I didn't get the deep creep). I was depressed, I just got one pop of blue smoke and a smelly interior for my troubles Never noticed it run any better either. Maybe i didn't get enough in the brake booster line, was a huge pain to get off, the engine barely could keep running with it off and it would stall out a gazillion times when trying to put in the seafoam drop by drop (yet it didn't when I dumped a bunch in at the end real quick, go figure).... sigh.
Maybe I just didn't do it right or something.
Old 02-07-2008, 10:09 PM
tspence45's Avatar
I just seafoamed my car a few days ago. It has just over 123k on it. It was a nice smoke show. It does run a little smoother than before. Now, I just have to change the oil in a couple days, since you're only supposed to go 250 miles or less after putting it in the oil. My car also didn't want to stay running with the brake boost line unhooked. I had to have my friend rev it a tiny bit just to keep the damn car going. It smoked out his whole shed, even with all the doors open for ventilation, while I was putting it in the brake boost line. I made sure to push it outside before starting it back up again. I think the part that did the most for me, was using the Deep Creep in the TB. I did it about a week before everything else, and it was filthy as hell. It ran a lot nicer after a good thorough cleaning. I used a tooth brush, like it said you could do on the bottle, and there was so much black gunk on it.
Old 02-07-2008, 11:39 PM
chromeplated500's Avatar
i use seafoam and STP gas treatment... on alot of things with no problem... 140k 92 chevy truck, 195k 95 chevy truck no problems... I put 3 bottles through my 92 throughout 5 tanks of gas... and it improoved my gas mileage noticeably...
Old 02-07-2008, 11:40 PM
and to make a point.... only 1 in 40 will tell you they liked a product or that it didnt cause a problem... but 1 person will always tell you if it ruined their cheap jeep engine..
Old 02-08-2008, 01:21 AM
chevyss3460's Avatar
I have a 99 SS with 101K miles and I just seafoamed it today and it made a huge difference. It did not cause any harm what so ever. As long as you use the proper recommended amounts and drain the oil no longer than 250 miles after pouring it in, you should have no problems at all. I also don't recommend driving it hard while the seafoam is in your oil. I drained my oil after approx. 120 miles of driving and the oil came out filthy, indicating that it worked.
Old 02-08-2008, 05:33 PM
tspence45's Avatar
I just changed my oil today after seafoaming. It was probably around 100 miles after and the oil was black as hell. It was just plain nasty. Good to know that the Seafoam was doing its job though.
Old 02-08-2008, 05:35 PM
SparkyJJO's Avatar
my oil was really black and nasty too when I changed it after seafoaming, so I guess even though I might not notice much it can't have been a waste, got the crap out of the engine.
Old 02-09-2008, 12:46 AM
tording99Z28's Avatar
I did mine a couple months ago and it did not smoke really at all. Just a little smoke from the pipes initially but nothing like everyone says it should do at all. It has 123k miles on it but I did not do the deep creep because the auto parts store did not have it. Is this why it did not smoke really? I didnt see any negative effects from it but I can't say I saw any positives really either.
Old 02-09-2008, 12:57 AM
tspence45's Avatar
All my smoke came from putting it in the brake boost line, I believe. The deep creep made mine smoke a little when I just did it by itself, but not much.
Old 02-09-2008, 01:03 AM
Yeah, when I put it in the brake boost line a little smoke came out but not a whole lot. Not like everyone makes it sound it should be. The car runs good though and I just bought it back in Nov so maybe the previous owner had just done it not long ago.
Old 02-09-2008, 01:26 AM
tspence45's Avatar
Yeah, it's a possibility. Or maybe, over the years, your car has just been maintained a little better than most. My car looks flawless inside and out, but there was definately some carbon buildup in the motor. All gone now though.
Old 02-09-2008, 04:38 AM
  #32
SlowSS416's Avatar
that stuff is awsome!!!
