T/A Headlights Open/Close When Locking/Unlocking
I am guessing an electricla connection must of gotten wet. Any ideas about where to start the search?
I did that and it worked great until we got the brass gears. It's really easy, let us know how it goes if you decide to do it.
maybe this write-up will give you some help. It's the site I got the brass gears from. It will also give you an idea of how to remove the motor and flip the plastic gear as a temp fix like I told you about.
http://www.bfranker.badz28.com/headlightfix/index.htm
Buying new GM motors still leaves you with the original problem: the weak plastic gear that will just strip again and cause the same issue.
When I lock the car using the fob the lights go up and down . It has never done it until this morning.
DIAGONOSIS: Headlight gears are stripped, remove and rotate for now and order brass gears, will never happen again.
I'd be another for the brass gears. Buddy of mine bought a new motor and replaced it, it started gringing again in 2 weeks and got down right irate about it. Save the heart ache and get the brass gears. That's my .02
Needless to say it sucked horribly and I went 2 weeks without being able to drive my car until I saved up enough money for a shop to butt rape me with the bill to fix it.
I had never heard of the lights opening/closing. thanks for the explanation about the sensor.
Maybe it should be a sticky in this forum too, since alot of members dont check the Firebird forum
