Sponsored by: CARiD
00' ta keeps blowing headlights
Old Mar 5, 2008 | 09:28 AM
xterminator's Avatar
Default 00' ta keeps blowing headlights
i tried a search but couldnt find anything on this. i have owned my ta for almost a year and in that time i have had to replace the low beams at least twice on each side. they keep blowing out about once every 2 or 3 months, is this normal?
Old Mar 6, 2008 | 08:02 AM
anyone?
Old Mar 6, 2008 | 11:58 AM
go-t's Avatar
Ive had mine for 2years and haven replaced a lights yet
Old Mar 6, 2008 | 01:44 PM
Joshiedoom's Avatar
I change mine often as well. Get new plugs(they are cheap at the otterzone) and grease the crap outta them... it helps...
Old Mar 6, 2008 | 02:58 PM
Darkreign2049's Avatar
I had both low beams go at the exact same time. 4 or 5 months after I got the car. Went into the restaurant came out and no worky. Never had both go out at the same time on any vehicle I've had.
Old Mar 6, 2008 | 03:43 PM
1994Z28Lt1's Avatar
i've had this happen on my car, did it happen shortly after startup? i find that when my alternator is cold it runs a lot more voltage than i would like usually in the high 14 range sometimes low 15's, im not sure if the voltage regulator is the problem, i've also heard the problem is worsened if you're running an optima, are you running an optima?
Old Mar 7, 2008 | 09:57 AM
no i dont have an optima just an exide. ill try some bulb grease on the plugs this time. this is getting old replacing headlights all the time
Old Mar 7, 2008 | 09:59 AM
i dont really know when it went out, i was just driving and got behind someone at a red light and noticed my recflection in their bumper
Old Mar 7, 2008 | 11:04 AM
01WS6/tamu's Avatar
Optima will not cause the problem. Leave the heresay as just that. I had a couple of them quit on my car. I changed to the wagner brite lights that have a zenon bulb and they are still going. I sold the car a couple of years ago but the new owner lets us do all of the service on it.
Old Mar 7, 2008 | 05:00 PM
zman1969's Avatar
Default Headlights
I went thru several on my 99 turned out i had loose connecters at the bulb- one finally melted - bought replacement connecter - no more problems - other than DRL-Daytime running lights - those get smoked often - i think i need new park light housings - ive had lots of little electrical gremlins with this thing!
Old Mar 7, 2008 | 09:02 PM
Joshiedoom's Avatar
Its a poor design..if you look at the connector when it click into the housing it is directly in the openings on the vents for the brakes(in the bumper) Rain Snow Sleet and other debris can all get in there.. Its a design flaw that needs to be addressed. Id like to get some new DRLS and make them where the connector is on top...
Old Mar 7, 2008 | 09:29 PM
ghardester's Avatar
I have had 3 Birds in the last 10 years. I always keep at least one spare headlight at home. It is also caused from the way the headlight doors slam shut. You have a light that's hot, turn it off and then slam!! the door closed.
To the original poster: Since my first '97 to the WS6 today I have changed about 15 or more head lights. The same with all 3 Birds that I have had, a couple lights a year.
Old Mar 8, 2008 | 06:21 AM
wow that really sucks. these are $10 cars with a $100 dollar motor lol. really there are a lot of little things that are screwy on these cars, its nothing major just little annoying things. i came from a terminator to this car and i really like the looks of the f-body and the ls1 is great but in my mind the cobra was just a more well built car, or better designed anyway.
