Sponsored by: CARiD
how to replace tensioner pulley
Old Mar 6, 2008 | 09:19 PM
not_my_z's Avatar
Default how to replace tensioner pulley
How do you replace the main tensioner pulley (on the top passenger side)?
I assume you just undo the bolt in the middle, but I tried as hard as I could, but the bolt wouldn't budge. Am I just weak?
Old Mar 6, 2008 | 09:29 PM
RAGENZ28's Avatar
I just replaced mine, are you sure you're turning it the right way? You can always try a longer wrench it shouldn't be that hard if it is try the other direction.
Old Mar 6, 2008 | 09:37 PM
Grimes's Avatar
haha, get a longer wrench. the bolt will come off!
Old Mar 6, 2008 | 09:52 PM
scoob's Avatar
I replaced one but it wasn't just the pulley, it came as the whole assembly. Held on by two bolts if I remember correctly. Maybe yours is like that and that bolt isn't supposed to move?
Old Mar 7, 2008 | 05:53 PM
not_my_z's Avatar
Alright, I got.
After borrowing a neighbor's longer wrench and giving it a healthy dose of WD-40, it finally gave.
Thanks.
Old Mar 9, 2008 | 09:14 AM
Schnell's Avatar
Why don't you do the regrease mod the someone posted on here.
Old Mar 9, 2008 | 11:05 AM
not_my_z's Avatar
I thought about re-greasing it, but I didn't have any grease on-hand, and a new pulley was only like $11 at autozone. I figured $11 wasn't going to break the bank. If this new pulley also starts to act up soon, then I'll probably look into re-greasing it.
Old Mar 9, 2008 | 11:27 AM
Formula413's Avatar
You would probably be well advised to grease the new one, it probably didn't come with enough from the factory which will lead to premature failure. That's why the originals crap out.
Old Mar 10, 2008 | 08:37 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I actually bought an aftermarket aluminum pulley with higher sides to hold belt better and dress nose cap when my stocker went.
The version I bought has a removeable bearing feature, so if bearing ever goes bad again - all you have to do is replace the bearing itself.
Old May 29, 2008 | 12:21 PM
qwk93ta's Avatar
who did you buy this from?
Old May 29, 2008 | 12:31 PM
z28matt's Avatar
is this a pretty easy fix, because mine just going out now too.
