Car acting up after Longtube Header Install
Old 03-25-2008, 01:28 AM
02BlackMachine's Avatar
Unhappy Car acting up after Longtube Header Install
Ive been running on open headers on my car for about a month now, and since the day i drove it , around 45 mph and higher it feels like its sputtering , a friend of mine told me its because i dont have the rest of my y pipe on there just headers and thats it.it's getting poor gas mileage ,and the main thing is that it lags when i try to floor it . any help would do or suggestions...it also feels like ive lost horsepower
Last edited by 02BlackMachine; 03-25-2008 at 01:33 AM. Reason: adding extra comment
Old 03-25-2008, 02:07 AM
BLACK2001SS's Avatar
Any codes?
after I did my heads I ran it with open headers it was running kinda crapy it was back firing and crap after I put the y on no problems. YOu might need a little tune.
Old 03-25-2008, 02:08 AM
yeah it threw codes for the rear 02sensors P0140 and P0146 ... so its backfiring because i need backpressure???
Old 03-25-2008, 02:24 AM
Not 100% shure on that back pressure thing I think its more that your car is running too rich or somthing along that lines, I have a cut out just a cupple more feet back so I dont think back pressure has anything to do with it, its your O2's that are telling your car how to run. I think that back pressure is like the Easter Bunny.
Old 03-25-2008, 02:32 AM
1994Z28Lt1's Avatar
its cool if you want to run open headers but the oxygen sensors are too close to the openings at the collectors, you are probably drawing a little air back into the exhaust causing the oxygen sensors to see a lean condition which is causing your car to run rich, pull a plug or two i'll bet they're black as night
you need to run some extensions on the ends of the collectors with a turndown or something so the oxygen sensors can get an accurate reading
Old 03-25-2008, 02:48 AM
would i need an extension even though i have high flow merge collectors??
Old 03-25-2008, 02:52 AM
how about bad spark plugs , would that cause it??? ive never changed my plugs on my car ever since i bought it brand new , it only has 47,000 miles on it.
Old 03-25-2008, 03:42 AM
If you have a code reader you might see a missfire code on it and your SES light will not set.
SO as far as bad spark plug I I dont think so but pull one out if you feal like it. like said above its your 02's reading lean so your car is running too rich thats my guess.
