Sponsored by: CARiD
ac problem
Old Mar 25, 2008 | 03:16 PM
Cherub's Avatar
Question ac problem
when I turn on the ac or heat it only blows out the defrost and at the feet. do I need to replace the switch?
Old Mar 25, 2008 | 10:31 PM
bww3588's Avatar
changed your intake manifold lately?
you lost a vacuum line on the back of the intake. its small and fits on the L fitting where the MAP sensor is.
Old Mar 26, 2008 | 11:00 PM
Cherub's Avatar
I will check that. Thanks
Old Mar 27, 2008 | 09:34 PM
Grimlock's Avatar
I am glad I found this thread. Me and a friend just changed the ls1 for a ls6 intake and everything is much better (cam is more defined). Went down the road, turned on the a/c and WTH? A/c at my feet! I had no idea what to think and either did he when I called him but we will check that too.
Old Mar 29, 2008 | 07:15 PM
yeller_xtc's Avatar
my car blows all the time at my feet ac or heat you think thats my problem too?
blows even if its switched off...
Old Mar 29, 2008 | 07:21 PM
9000th01ss's Avatar
It could be a bad switch but you will hear a hissing sound by the switch if it is.
It's usually the vacuum line disconnected or broken somewhere between the intake and where it goes through the firewall.
Old Mar 29, 2008 | 07:55 PM
Wsteun's Avatar
I changed my intake manifold lately, and my A/C only blows out of my defrost vents. But I'm positive that I plugged the line back in. It's the one that runs to the brake booster right?
Old Mar 29, 2008 | 08:49 PM
Wsteun's Avatar
Actually, scratch my last post. I had no idea there was a Tiny connector underneath the map sensor. I just looked at the one on my LS1 intake. I definitely forgot to connect that. I suppose I have to pull the manifold to fix it?
Old Mar 29, 2008 | 09:00 PM
Candyredz28's Avatar
that just happened to me, I switched the intake lately to and a ls6 and broke the vacuum thing, so I had to make one weird looking one myself, anybody knows where they sell the whole line.
Old Mar 30, 2008 | 12:15 AM
Wsteun's Avatar
Also, where to the firewall does this line run? So that I might be able to find it when I look for it?
Old Mar 30, 2008 | 02:22 PM
Its just behind the intake on the passenger side, beside the map sensor, it mignt not be broken there, it might me broken some where down the middle, the line is real fragile. or just trace the line all the way to the back of the intake
Old Mar 31, 2008 | 12:20 AM
Wsteun's Avatar
I talked to a friend of mine, hes a GM tech. I told him about my AC thing and he goes "Oh did you forget to plug in that little line?" I was like how'd you know?
Said it's a small line right behind the MAP sensor, easiest way for me to do it is going to be to unbolt the last 2 Coils (98's bolted to the head individually ftl).
I hope I didn't break anything.
