Head or intake gasket
I'm french and i need advice for my 3.8L camaro.
I loose a little coolant, maybe 25cl in 200km.
I have water on my oil cap, don't know if it's coolant or condensation. (the temp is between 0-5°C)
The car run great, never overheated, start in a second.
It smoke a very little when hot but it's cold outside and it rain.
Some guy in us tell me it's the intake gasket, i have bought all the parts to do it.
In france they tell me it's the head gasket.
But for me the headgasket will affect more the car, no?
Could you help me?
Thanks
I know three persons in france that have oil on rad cap.
I consume 0.5L of oil in 4000km.
The oil on dipstick look normal, no moisture on it.
I could see water on the front of the engine, behind the pulley, on the left side.
I'd check for leaks in the radiator and hoses maby you have a leak and dont know it because when the car is running you have more pressure in you coolant system and thats when it could be leaking but when its sitting it might not show signs of leaking at all.
Most all cars have white smoke when you start it, its just condensation but if it smells sweet then you have a problem ( you dont have to stick your nose in the tail pipe you can just stand buy to see if it smell sweet).
Their is somthing about the green mixing with the orange that causes it to gel up the water will just evaporate. I've seen this problem several times my friend had a blazer where it did that just a month ago he said it was overheating and he had to put coolant in it, the guy befor him Mixed it and then he put more Green into the orange big no no in my book.
If you have this problem get your radiator and whole engine flushed 2 times at least then put a new radiator on, thats what I'd do.
You can also do a pressure check on your radiator/thermostat most all radiator shops can do this for cheep.
just some ideas.
There is no bubbles on the rad when the car is idling but the level raise up so i replace the cap.
At wot i couldn't see smoke on exhaust.
When i flushed the coolant i couldn't flush more than 3/4.
My coolant was clear but with the time the oil reappeared.
If this is a head gasket it will be more noticiable no?
My engine temp is behind the 1/4 when i running, when i let the car idling it raised on the 1/2.
A bad head gasket leak you will see that your oil is milky and over full.
