Possible causes of engine tapping
This past saturday I started hearing a tapping noise, but duller than the clatter the lifters made. At idle it is audible, but not bad, becomes much more noticeable at 2500RPM and up. As I rev it, it gets faster, but if I rev it up to, say, 3000RPM, then let off the gas the sound pretty much disappears until right before the RPM gets down near idle and the sound then comes back with the first few taps much slower and slowing down between each tap, then to the steady tap-tap-tap at idle (about 3-4 taps a second at an idle of 800-900RPM - this is my V6 A4).
I used a hose to the ear and traced it to cylinder 3. Hose at the top of the valve cover, nothing much. Base of the valve cover, right above the exhaust manifold it is quite audible through the hose. This leads me to believe that it is either a pushrod or a lifter. Thinking it probably isn't a lifter because the sound is duller tapping compared to the harsh clacking the lifters made when they went bad. Someone also suggested it could be an exhaust leak, could an exhaust leak sound like that? Makes me wonder since the sound goes almost totally away when letting off the gas.
Since this has started, aside from a quick rev here and there when I was tracing it, I haven't let it get above 3000RPM in case this could be more major.
Could a messed up IAC cause that? Besides cleaning the MAF that's the only thing I did to it, so I'm guessing it could be. $32 at Autozone gets a new one though so no biggie if I did screw it up. I did forget to pull the battery connection after cleaning the MAF to reset the computer, so I did that last night. Who knows, maybe that'll fix it.
I think the stall issue is resolved, pulling the battery and having the car relearn seems to have fixed it, I tried to stall it several times today and it wouldn't.
Oh yeah the mirror is easy, took a look at it a while back, just haven't wanted to do anything with it until I'm ready to fix the rest of the bodywork and paint it. This mirror may be damaged but it is still functional and the color matches at least
So now what do I do? I don't have much money, only a few hundred, another V6 engine with 50K miles looks like it'll cost around $2500 installed. Considering the shape of the rest of the car (body work primarily), is it worth it? Assuming i could come up with the money somehow... I'm a college student, I don't have a whole lot of money to throw around.
This burns, replaced lifters 2 months ago and now the bottom end quits at 110K miles. I shouldn't have bought this car seeing that it had been abused...
Any input?
I guess the plus of this is my worn water pump, alternator, and seeping PS pump (so I was told, hadn't had to top it off yet) are all taken care of this way since the "new" motor has all that already.
