Sponsored by: CARiD
No daytime running lights
Old Apr 11, 2008 | 07:59 PM
BTTM's Avatar
Default No daytime running lights
Just replaced my turn signal bulbs as one had blown, now I have no daytime running lights and the turn signals don't work. When I turn on the hazards, they work fine. I've checked the fuses. Anyone know anywhere else I can look?
Old Apr 11, 2008 | 08:09 PM
VINCE TA's Avatar
check your sokets!!!! are they corroed????
Old Apr 14, 2008 | 09:54 AM
BTTM's Avatar
Checked the sockets and they aren't corroded. I replaced them about 6 months ago. Anything else I can look at?
Old Apr 14, 2008 | 10:58 AM
1FST-Z's Avatar
Umm from what I understand, there is a DRL control module inside the dash, behind the radio.
Old Apr 14, 2008 | 02:13 PM
BTTM's Avatar
Ok, I'll check that next. Thanks!
Old Apr 14, 2008 | 02:39 PM
99Z2ate's Avatar
You may need to replace your turn signal flasher, especially if you just installed LED's.
Old Apr 14, 2008 | 11:14 PM
wssix99's Avatar
Save the manuals!
What type of bulb did you put in? Did you try putting the old ones back to see what happens? (Sounds like one of them was still good?)
Old Apr 15, 2008 | 09:34 PM
BTTM's Avatar
The passenger side was working fine. The driver side bulb was blown prompting me to change both. I just used oem bulbs, nothing fancy or an upgrade.
Where is the turn signal flasher found?
Old Apr 15, 2008 | 10:24 PM
LS1_Fonzie's Avatar
Flasher is under the steering column. There are 3 or 4 screws holding the plastic piece under the steering column, take that off, it's off towards the right side if I remember correctly. Unplug and put in the new one.
Old Apr 16, 2008 | 08:35 AM
wssix99's Avatar
Save the manuals!
Are you sure you have the right model # for the new bulbs? (For the front, you need a 3457 bulb.) There are some other model numbers that look almost the same and fit the sockets, but won't work.
Old Apr 17, 2008 | 08:55 AM
BTTM's Avatar
Figured it out, I think! Looks like the wires came out of the driver side plug, which, I didn't know until know, throws the whole system out of whack.
I'll fix that this weekend and hopefully that will do it. Thanks for everyone's help.
Old Apr 23, 2008 | 12:26 PM
BTTM's Avatar
Update, fixing the plug didn't fix it. Checking the DRL control module next.
