What did the dealership charge you to change the window motor?
Old 04-27-2008, 07:05 PM
slayerized6's Avatar
ive had any autozone window motor in my car since dec 2007. never had any problems with it. plus its a lifetime warranty. i paid like $20 for it and i installed it in less than 1.5 hours. if i had to do it again i could do it in less than 45 min
Old 04-27-2008, 08:00 PM
Badguy7's Avatar
SLAYERIZED6: Did you have to modify anything, or did it fit right in?? I need to get new motor's for my window's. Driverside is dying down on me, and passenger side is slow.
Old 04-28-2008, 04:23 PM
Formula413's Avatar
BTW, this is the Shoebox guide:
http://shbox.com/page/windowmotor.html
But diagnose the problem before you buy a new motor, if it does nothing at all start by checking for voltage at the motor, then check fuses, wiring etc.
Old 04-28-2008, 07:50 PM
SparkyJJO's Avatar
I got my motors off ebay, $45 for two so I have a spare
Driver side was dead when I bought the car, passenger one still works. Thought that was odd since the passenger is usually first to go.
I did the motor the hard way "to the book" before I knew of the shoebox guide. Argh, a royal pain, still not quite aligned right. That shoebox guide looks like a piece of cake.
Old 04-28-2008, 10:01 PM
Shooter_Jay's Avatar
probably 400 at the dealer. I'll do it for 250 for everyting, I'm 45min. north of worcester.
Old 04-29-2008, 06:05 PM
Moderator
davered00ss's Avatar
might pm you. I think I'm going to try it myself.
Old 04-29-2008, 06:06 PM
Moderator
I'm 30 min south of worchester.
Old 04-29-2008, 06:13 PM
Yeah that's why I said it. I remember seeing you at lvd a few years back when I bought my car.
Old 04-30-2008, 04:19 PM
mikerulzu's Avatar
I got mine done at a pretty reputable shop in town, and paid $85 for labor.
Old 04-30-2008, 06:48 PM
Moderator
I remember who you are now. We talked when I was putting air in the tires before leaving.
Old 04-30-2008, 06:49 PM
Moderator
My car ran like **** that day. But Don did run a 12.6 in it. I was all over the place.
Old 05-01-2008, 03:47 PM
  #32
TFFMP's Avatar
Originally Posted by Mike2kZ
It's especially easy if you drill the holes for easy access.
Do it yourself. You'll learn something and smile every time you open/close your window knowing you fixed it.
x2
Drill the holes so you can see / access whats back there. I found my little mirror on a stick pretty helpful too.
I think out of everything, getting the damn door lock slider thing back in was harder than anything!
Old 05-01-2008, 03:52 PM
  #33
TFFMP's Avatar
Originally Posted by 98boxer
My driver window motor are acting up. Gets stuck sometimes and slowly i have to push the button to close the window.
The problem i've heard about AutoZone motors is that sometimes at the very top the motor doesn't seem to seal right. So im a little worried about going to aftermarket window motors.
Has anyone had there auto zone window motors seem to not have a tight fit at the top of the window?
Which motors do the dealership us?
Autozone motors here... no issues. If anything, the motor itself is underpowered for such a large / heavy piece of glass. Heck, even after the new motors went in, I still think the windows are slow. Hey, maybe we can come up with a window motor mod and cut thjat up and down time?? lol
And I'm not talking about saving tenths... we need to save seconds here! ha
Old 05-01-2008, 05:08 PM
  #34
Moderator
A mechanic friend of mine printed out the instructions from an online service manual the company has. He is in charge of fleet maintenance for the co. I work for and is going to help me do it in the co. garage after work. Probably do it tuesday.
Old 05-04-2008, 11:23 AM
  #35
Ntimid8r7's Avatar
Originally Posted by TFFMP
x2
That is exactly what I was gonna say! There is a trick to popping it back on. Just put everything back together and slide the slider in thru the front of the opening and use the door handle plate to pop the slider arm in. Make sure the arm is in unlocked position. no fuss, no fighting. You just have to stop and think. They are not gonna make it a pain in the *** on the assembly line.
Old 05-04-2008, 03:47 PM
  #36
Moderator
Bought the motor for $58 @ AutoZone. Will install it Tuesday nite with a friend who is an auto mechanic working on GM fleet vehicles.
Old 05-04-2008, 05:12 PM
  #37
Relapse's Avatar
Use a rivet gun instead of the bolts they give you, if you have access to one that is
Old 05-04-2008, 09:37 PM
  #38
Restricted User
socmguy's Avatar
yep! I prefer to rivet them back in as well so they don't come loose.
Old 05-05-2008, 01:35 PM
  #39
ChicagoTransAm's Avatar
Hey man.. if you want, you can drive it up here. I'll do it for the low low price of watching you drive up here to get the motor done.
Old 05-05-2008, 02:50 PM
  #40
94'BLKBRD's Avatar
I got my window motor from Autozone for $57 w/lifetime warranty. It took me about 1hr 30min to get it done. It's real easy, just follow the Shoebox instructions.
