95 trans am lt1 water pump
where do i buy water pump and air filter elbow pipe for my trans am? i am looking for cheapest place but don't want total junk. i have big coolant leak from water pump area. does that mean that waterpump it gone? also my air intake elbow is torn up by PO and i need a new one. i got no money now and this is really bad timing so I'll have to do all the work myself and need cheap parts. advice please.
Call around or check the sponsors for the best price, or maybe get a rebuilt one. I went to shoeboxe's PN list and the pump is GM PN 12527741. Plugged it into gmpartsdirect and dealer list was just over $400!
http://shbox.com/ci/water_pump.jpg
to know if the pump is bad, get under the car and check the bottom of the pump. you will see a hole. we call it a weep hole. see if its discolored or dripping. i know when mine went, it dumped all the coolant in the publix parking lot in the matter of minutes. sucked. honestly, if you dont have much cash but are pretty handy, just get an auto part store lifetime gaurantee pump. if it goes bad again, they will give you a new one if you still have the receipt. i used to pull a water pump from my old lt1 by myself in 30 minutes. not bad once you have the routine down.
check ebay for the intake elbow.
If you havent already, check all of your hoses to see if they have sprung a leak. Had it happen more than once when I had my 97. Was going to suggest replacing your optispark if you replace your water pump, cause its damn near guaranteed that it will go out soon after. Mine was the day after I put the new water pump on lol.
I got the pump for my LT1 for $129 with a lifetime warranty from a small local auto parts store. Dont let it leak or it will take out your optispark! You think the waterpump sucks wait till you have to do an optispark! Check your thermostat gasket and the weep hole to be sure...as for the elbow look in the for sale section and post up in the wanted section.
just another question before i dig in. what else should i change while i am there? maybe gaskets or something else? what should i buy besides for the pump (got it for 55 bucks yesterday because they didn't have anything else in stock)
