engine overheating, car shakes violently?
By unplugging them you can tell if the 02's are bad.
unplug them, if the car runs better, then you need new 02's, if not move on to the next part, ignition.
the reason the temp goes up and then down when you hit the gas is because the water pump is spinning faster and flowing a larger mass of coolant. cooling the sensor
