98 Z28 idle issues!!
Something to try with the idle bobbing, when it starts push the gas a tiny bit to give a slight rev for a second or two to see if it smooths out and then let off and see if it drops to normal. I found I can get the idle under control quickly that way if it doesn't fix itself within a couple seconds.
Do a compression check.
I had a car with a fairly bad missfire, I replaced all the ignition components then the injectors. Six months later I did a compression check to find the one cylinder had only about 65 PSI.
To the OP, it kinda sounds like your PCM is trying to relearn some parameters, don't know why though.
Could the OP's issue be a weak battery perhaps?
