oil filter stuck
Old 09-19-2008, 02:04 PM
texasglock23's Avatar
Default oil filter stuck
Why in the hell am I having such bad luck with this car so far? I attempted to change the oil today and first the drain plug was stripping and was a PITA. I get another and replace it. The filter was on super tight thanks to the dealer. I tried a screwdriver which made it worse. Strap wrence failed first, I went back and got the socket style and it won't grap on to the filter now that it was crushed and piereced. WTF am I suppose to do now?
Old 09-19-2008, 02:09 PM
kyles2000z's Avatar
looks like whoever changed the oil last didnt run a little oil on the seal on top of the filter. good luck to ya
Old 09-19-2008, 02:21 PM
That or the TOOL cranked down on the filter!
Old 09-19-2008, 02:24 PM
2001NBMZ28's Avatar
Don't know how mangled it is now, but I'd try wrapping one (maybe two) latex dishwashing gloves around it for grip and try the strap wrench again. Make sure the old filter seal comes off. I think K&N filters still have a large "nut" built into the bottom of their filters. Hang in there, you'll get it.
Old 09-19-2008, 02:30 PM
I used rags for the socket style wrench, but nothing. I can't get the strap style to work. There isn't enough room for me to tighten down and turn.
Old 09-19-2008, 02:58 PM
CamaroFan71's Avatar
Large pair of channel-lock pliers.
Old 09-19-2008, 03:00 PM
question's Avatar
When you pierced it with a screw driver where you absolutely positive to go through the MIDDLE of the filter element? Piercing anywhere other than the middle will result in simply stripping the aluminum. Worst case scenario the filter may be cross threaded but thats a shot in the dark.
Old 09-19-2008, 03:06 PM
2001NBMZ28's Avatar
Don't think rags will work, especially since it's been pierced and oily. Try latex gloves. Large channel-lock pliers is a great idea.
It wasn't in the middle, a bit below.
Old 09-19-2008, 03:09 PM
question's Avatar
You want to stab that sucker directly in the middle into the thickest part of metal you can find. I've literally ripped an oil filter to shreds till I found 'the spot' where the amount of force required to twist off the filter was LESS than the amount of force required to shred the metal. Make sense? I've never had the 'stab an turn' method fail. When putting the new one on like said earlier don't forget to prime it and lube the seal.
Old 09-19-2008, 03:15 PM
I'm headed to Walmart to get the plier style wrench.
Old 09-19-2008, 03:19 PM
question's Avatar
That'll pry make things a bit easier. I am sure by now you have nasty black puddles in the drive way, kitty litter scattered everywhere. Hell, you pry came in dirtier than dirt after fighting with the plug an filter. Trust me, we've been there. Best of luck to ya, and remember that sucker only needs to be a tad more than hand tight.
Old 09-19-2008, 03:34 PM
peterock98's Avatar
Buy yourself big a pair channel locks and you good to go.Open the jaws wide and grab the bottom of the oil filter and turn to the left.
Old 09-19-2008, 03:35 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Try the screw driver again. I have demolished a filter or two but eventually they do come off. Good luck
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-19-2008, 03:44 PM
samson_420's Avatar
Try to clean it with degreaser then either use chanel locks or a damn good strap wrench.
I have mangled my share of stuck on oil filters from previous owners.
You shoud be able to get the damn thing off.
This still does not compare to my VW Beetle. I went to tighten the drain plug and it just kept on spinning. Yup, that's right it striped so bad it would not come out with anything. I had to replace the oil pan. . . . The fine engineers of VW left the threads sof aluminum. . . . Thanks. . . . Really.
Old 09-19-2008, 03:51 PM
question's Avatar
X2, you just gotta poke her in the right spot.
Old 09-19-2008, 03:54 PM
BlacKBirD25's Avatar
take the screwdriver and hammer and just tap it right at the rim untill u get it to spin.. may take awhile but it will knock it loose, ive had this problem before
Old 09-19-2008, 05:32 PM
Still nothing. I need serious help.
Old 09-19-2008, 08:34 PM
peterock98's Avatar
I have longtube headers and the channel lock works.Grab it from underneath.
Old 09-19-2008, 08:55 PM
bluestrat's Avatar
Had this happen then crushed the **** out of the filter. I ended up wrapping a bunch of duct tape around the ****** then gripped up at the top of it with my filter wrench and it finally came loose. Now I always run the K&N filter with the hex on the bottom so I can take it off with a crecent wrench
