Sponsored by: CARiD
Steering click
Old Oct 7, 2008 | 01:59 AM
2000Z28ls1's Avatar
Default Steering click
When ever I turn my steering wheel more than say 20 degrees I get a clicking coming from the front of the car. any ideas on what it could be I know im not giving you much to work with but do you think maybe the rack and pinion are grinding, maybe dirt in there, could one of hte nuckles on the shaft need lubes(can you even lube them). I know nothing about this part of cars any help would be awsome.Btw it is all factory power steering for a 2000 z28
thank jim
Old Oct 7, 2008 | 08:36 AM
Grimes's Avatar
is it a constant clicking, or just one click once you turn it?
Old Oct 7, 2008 | 10:13 AM
2002_Z28_Six_Speed's Avatar
Is it a click or a pop? A click could be the collapsible steering shafts. Nothing you could do about that really.
Old Oct 8, 2008 | 10:07 AM
2000Z28ls1's Avatar
It not sure the diffrence maybe more of a pop, when I get the wheel at around 50-60 degrees there are about 3 clicks/pops in either direction of the wheel coming from the front under the hood of the car.
Old Oct 8, 2008 | 12:04 PM
I don't think that is the steering shafts then.
Old Oct 8, 2008 | 11:02 PM
2000Z28ls1's Avatar
maybe dirt or something got inside the rack and pinion, and its is in the imput shaft groves making it click, if it works anything like I think it does. but I might be wrong
Old Oct 9, 2008 | 08:32 AM
WayneSS01's Avatar
When I turned left the front passenger side wheel would click. Replaced the hub assembly and no more clicking.
Old Oct 12, 2008 | 01:32 PM
2000Z28ls1's Avatar
I do have a bad wheel bearing I think, how hard are they to replace I know the whole assembly is like 250 bucks.
Old Oct 12, 2008 | 11:57 PM
That sounds about right the last time I got one. 230 ish dollars. I would get a GM one though. I don't trust the aftermarket although the point that the "aftermarket" one might be an OEM sold under the original company. This might be true because who would have the tooling to make that part?
I didn't wouldn't take the chance though.
They aren't that hard to put in. Remember to have a chisel, flatbladed screwdriver, and hammer on hand to help you get the old hub out.
Use locktite for sure on those bolts.
Old Oct 13, 2008 | 12:01 AM
jsteele90's Avatar
could be an endlink. mine did it after i installed my ws6 sway bar. i didnt have them tight enuf
Old Oct 14, 2008 | 11:58 AM
2000Z28ls1's Avatar
k I do have a strano sway bar that was put on maybe 6 months ago but it didnt start till recently. I gotta get under it but I moved to this apt and I dont have a my jack right around or anything. Thanks for the imput so far guys
