P0135 questions. please stop in if you've had this code
P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
This is a common code after a header install. It comes back after you delete it i see. Sometimes the car missfires and sometimes the converter won't lock. Then a new issue today...the cruise control wouldn't work.
As soon as i delete the code, all my problems go away. How do i permanently fix this? tune it out?
Did you have to install O2 bungs or were they already in the headers?? Well what kind are they as well?? That code means the tip of the O2 is not getting hot enough to register a true reading to the PCM...
Same thing happened to me. I just replaced them w/ new sensors and it went away. Afterwards, I did weld the exhaust to the headers though to eliminate all leaks though. hope this helps.
well i had to drive back home with it this way. it did great for about 50 miles and started acting up again. i limped back home and my other car is out of commission too, because the serpentine belt is loose and idk if thats the tensioner or what, gotta get that fixed today somehow. it's raining...![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
i got a p0132 code too, high voltage bank 1 or something
