Replaced 02 Sensors now throws another code help...
ecm has detected the switch ratio of rich to lean and lean to rich was below a determined number
Probable Causes:
-Failed Heater Circuit
-Signaled Shorted to ECM ground
-Improper oxygen supply to sensor-check connectors and wires
i have tsp true duals dumped before the axles with qtp headers. the rear 02's were deleted. i replaced them with brand new bosch corvette 13111 sensors.
i checked the 02's everything is hooked up properly...
has anyone had anything like this before?
is this something to worry about?
