Muffler change only?
Old Oct 26, 2008 | 01:25 PM
ncbirdfan's Avatar
Default Muffler change only?
With the size of the pipes on my WS6, would I benefit from just a muffler change? Would the pipes in a cat back system really be an improvement over the stock pipes? The stock pipes look pretty big to me, except for the flattened spot in the Y-pipe under the driver.
Old Oct 26, 2008 | 01:30 PM
omcar's Avatar
I just have a muffler and slp y-pipe....check my sig.
Old Oct 26, 2008 | 01:41 PM
mean_greenZ's Avatar
pretty sure ls1's came with a stock 3" I-pipe.
Old Oct 26, 2008 | 02:45 PM
shdybrady1988's Avatar
My 02 came with a 3 inch and for awhile i had my headers and ory pipe. Stock catback. Then i i just cut the muffler out and added a magnaflow muffler. But you will benefit. It just depends on which muffler. The magnaflow is a great flowing muffler.
Old Oct 26, 2008 | 03:18 PM
9t8z28's Avatar
Your itermediate pipe (mid-pipe) is 2.75" No need to change it if you are doing just a muffler swap and yes you will benefit.
Old Oct 26, 2008 | 03:19 PM
jrob56's Avatar
i was under the impression the stock exhaust i pipe was 2.75, thats what mine is
Old Oct 26, 2008 | 09:52 PM
oh well maybe they are all 2.75" i just thought the ls1's had 3"
Old Oct 27, 2008 | 10:44 PM
RevGTO's Avatar
Pontiacerator
As long as you're going to be running stock manifolds, cats, and Y, there's really no benefit to going to a 3" I pipe. Just splice your favorite muffler in and you're doing fine. Save the I-pipe for when you do complete exhaust.
Old Oct 27, 2008 | 10:57 PM
krazy4's Avatar
Get a dynomax bullet, or a magnaflow muffler and dump it right off the Y-pipe. Makes power and is still pretty damn quiet.
My car made 354whp with a slp lid, slp maf, and a dumped magnaflow 4x9 off the y-pipe. Stock manifolds and cats.
Old Oct 28, 2008 | 01:01 AM
OMGls1jz's Avatar
wow 354 whp! thats good! i'm assuming thats with a tune? so you think if you got rid of the cats you'll gain more? how much more would you gain you think?
Old Oct 28, 2008 | 06:39 PM
qwickLT1WS6's Avatar
not that much
