NGK TR55 vs. AC Delco Rapid Fire #12....HELP
was wondering which of the two plugs were better and maybe some reasons to support your opinion:
Also what wires to use:
Taylor or MSD or Stock
Thanks
Thanks
Any fine wire electrode, like iridium, will jump the spark gap with much less voltage. You can run the iridiums with either a wider gap, or higher compression. For close to stock specs, the main feature is better durability. Unless the car has problems, you won't notice a difference. If you run into coil or plug wire issues later, the iridiums may prolong the onset of big problems.
