Thinking about making my own TDs.
Old Nov 2, 2008 | 05:15 PM
BlueBird346's Avatar
Default Thinking about making my own TDs.
I want to make my own, not take it to a shop. Im thinking about getting the Jegs street rod exhaust kit, an X pipe and some sweet thunders and welding it up myself. Has anyone else used this kit or something similar?
Old Nov 2, 2008 | 06:39 PM
cowboysfan's Avatar
shop in S.A. used a universal kit to build mine. all stainless steel. love it!!
Old Nov 2, 2008 | 07:25 PM
blown03mustang's Avatar
its not that hard, mine didnt even require many bends and mine have better clearance than most aftermarket exhaust!
just take your time and it shouldnt be that difficult
Old Nov 2, 2008 | 07:36 PM
Ok. Im also thinking about Magnaflows instead of sweet thunders. Right now i have LTs/ORY/TSP rumbler and its raspy as hell, which is why im doing this, but i like how loud it is. So i dont really want it to be too much louder or quieter than it is, just better tone and less rasp.
Old Nov 2, 2008 | 07:53 PM
the only problem i saw with goin with anything other than my bullets was ground clearance. u lose a ton with most mufflers and where you can actually put them is another problem. my dynomax bullets sound great and are not NEAR as loud as people made them out to be.
Old Nov 2, 2008 | 07:58 PM
I think the STs are actually smaller than the bullets, if im not mistaken. I can see having a clearance problem with the magnaflows tho.
Old Nov 2, 2008 | 08:09 PM
im not sure but i know my dynomax bullets are like 4" in diameter which took a little altering of the floor pan in a spot or two, but came out to almost a perfect fit. sounds great too
Old Nov 2, 2008 | 08:12 PM
Cool, do you have a soundclip?
Old Nov 3, 2008 | 02:13 PM
Old Nov 3, 2008 | 03:34 PM
Thanks that sounds pretty good.
Old Nov 4, 2008 | 03:51 PM
2k1bird's Avatar
I beat the bottom of the rear seats in a little on mine for a little more clearance. I went with the magnaflow mufflers and couldn't be happier. Pacesetter longtubes, H-pipe, magnaflows turned down before the axle. It's still loud, but it has a solid tone when you rev it.
Old Nov 4, 2008 | 03:58 PM
03Sssnake's Avatar
What shop? I am pretty much out of luck in my search for a competent exhaust shop here in austin that will turn a wrench on a car with no cats and longtubes I have been looking for a shop to fab something for me so I can ditch the crappy Y-pipe.
Old Nov 4, 2008 | 04:05 PM
wzup1000's Avatar
Solution: Take it to the shop on a trailer, take off your plates, and cover up the registration and inspection, tell them its a "drag car" and you should have no problems with them touching your car... Ive used this method before.
