HELP! UD Pulley
Old Nov 5, 2008 | 07:34 AM
MATTREDSS's Avatar
Default HELP! UD Pulley
Well I'm trying to get my under drive pulley on. Well the problem is that I can not get the damn crank bolt off.... I have used impact (air) and it will not budge , Help!!!!
Matt
Old Nov 5, 2008 | 08:14 AM
Weezzer's Avatar
You will need a long breaker bar and then a pipe over that and yer still gonna have to pull like hell, be sure yer pullin' in the right direction-thats a big plus as well...
Old Nov 5, 2008 | 11:15 AM
MikeG's Avatar
You are locking the trans correct? The motor isn't spinning?
Old Nov 5, 2008 | 11:20 AM
7camaro7's Avatar
if auto take off starter stick a screw driver in flexplate then get breaker bar.
if auto put in 4th and use breaker bar
Old Nov 5, 2008 | 11:42 AM
slt200mph's Avatar
I use a 24 inch breaker bar with a 36 inch pipe on it and then I pull like a ****..
Old Nov 5, 2008 | 12:32 PM
MATTREDSS's Avatar
I had it in park when I tried it. I will use a breaker bar when I try it again today also I will put in gear.
Thanks,
Matt
Old Nov 5, 2008 | 04:53 PM
chrs1313's Avatar
Thanks,
Matt
a weak impact will not get it off...you need to have an expensive one with a **** ton of torque...had the same problem...be careful putting a screw driver in the flexplate because you can break off a tooth...
Old Nov 5, 2008 | 05:00 PM
00SSLS1's Avatar
if you dont want to stick a screwdriver in your flex plate, you can get a flywheel lock to keep it from turning
Old Nov 5, 2008 | 06:14 PM
fbirdserge00's Avatar
i used a heavy duty impact gun from craftsman, it took a couple of good hits and the bolt came right off. i also used the impact to get the new pulley back on, but at the lowest setting once i got the bolt started
Old Nov 5, 2008 | 06:20 PM
2000Hawk's Avatar
I used my craftsman impact gun that came as a kit with my air compressor. Took quite a few hits, but eventually came loose. If that doesn't work just follow everyone elses tip of a breaker bar and a long pipe.
-Joel
Old Nov 5, 2008 | 07:58 PM
DaveX's Avatar
I wouldn't recommend the screwdriver in the flywheel trick. If you break a tooth off the flywheel or break the screwdriver off in there you are screwed, and both have happened. Summit sells a tool to lock the balancer/crank from spinning from the front. I used this with a long breaker bar and 4' pipe.
