Fan switch mod write-up
Old Nov 11, 2008 | 09:33 PM
firehawk#682's Avatar
Sorry i didn't mean compliant i meant thanks for the complements everyone. i can't type. and yes you are rite that sounds like a good option if you don't want to remove your pcm
Old Nov 13, 2008 | 02:21 PM
Originally Posted by TORCHD 02 TA
so lets say sometime in the spring you want to meet halfway to help me with this project?
Maybe we can work something out next spring
Old Nov 13, 2008 | 02:30 PM
TORCHD 02 TA's Avatar
saweeet sounds good
Old Nov 13, 2008 | 03:09 PM
Viper's Avatar
Nice write-up. Mine was the old fashioned one from 2000 or so where you tap into the fuse box on the driver's side, no led's and a flip switch under the steering wheel.
Old Dec 28, 2008 | 04:05 PM
Thanks for the info. Now lets see the final pic. Where did you mount the switch? Do you perfer the rocker switch over the toggle?
Old Dec 28, 2008 | 05:17 PM
I jsut bought the rocker switch and the 2 LEDs
EDIT: What gauge wire did you use? How many feet should i get?
Old Dec 28, 2008 | 05:34 PM
isenegger's Avatar
i might sound stupid but i really dont understand the wiring diagram. can you explain how it is wired up again? i ran the wires to the shifter and i have the switch but the wiring confues me.
Old Dec 28, 2008 | 10:48 PM
10 ft should be plenty but you can never have enough wire as you will use it more in the future. as for the gauge i think it was either 20 or 22 gauge.
Old Dec 28, 2008 | 10:59 PM
Do you have a pic with the switch mounted? Did you ever figure out what switch plate you are going with? I think i am goign with the cubby hole one
Old Dec 28, 2008 | 11:04 PM
not a stupid question at all. First of all you have to tape into the 2 wires on the fender like i showed you the blue and green wires here is a pic of the 2 wires taped. Then you run them 2 wires into the inside of the car and up under the center counsel.
Now you take the leds you bought and connect the to ends with the resistor the (anode side) together and wire them into a positive 12v sourse i just wired them into the cig. lighter.
Next take one led and take the other side of the led and connect it to the blue wire you ran into your car and connect that to one of the middle prongs on the switch. Then do the same with the other led and green wire and connect it to the other middle prong on the switch.
Last you have your ground wires. One the green wire side of the switch you ground both prongs and on the blue wire side of the switch you ground just one prong. I connected all the grounding wires together and then connected them to the ground wire off the cig. lighter.
Old Dec 28, 2008 | 11:08 PM
No i don't yet its just sitting there in my ashtray rite now my car is put away for the winter so ya i wont finish the switch panal till summer. My cut out is sitting im my room waiting till summer to be installed and my line lock. I guess im going to have to go with the cubby switch panel bc i don't think hes going to come out with the ashtray one. I haven't ordered anything yet bc i wont be doing anything till winter is over anyways so ill just wait till then.
Old Dec 28, 2008 | 11:14 PM
  #32
Yep that is what i was thinking. That he is not coming out with the ashtray.
I have my e-cutout wires ran already. I had a DMH back in 2005. Then got rid of it. And i kept all the wiring. I still have my switch in the ash tray. So i bought another DMH e-cutout that needs to be put in, in summer time.
But for the cubby hole plate, i will be adding e-cutout, fans, line lock (still need to buy)
I just bought a kill swithc too.
For the cubby hole plate, you going with the lighter provision (so you can still use your lighter) or w/o the lighter provisions?
sorry for the
Old Dec 28, 2008 | 11:29 PM
  #33
i also have a dmh cutout can't wait to get it in. I haven't decided yet but im leaning towards keeping the cig lighter, cuz i will only have 3 switches so i probably going to keep it.
Old Dec 29, 2008 | 05:02 PM
  #34
Viper's Avatar
"I connected all the grounding wires together and then connected them to the ground wire off the cig. lighter."
What color is the ground off the cig lighter?
Thanks
Old Dec 29, 2008 | 06:23 PM
  #35
isenegger's Avatar
so the toggle switch has to have 6 prongs not just 3?
Old Dec 29, 2008 | 09:35 PM
  #36
Thanks
on my car it was the black one and the orange one was the positive
Old Dec 29, 2008 | 09:39 PM
  #37
yes 6 prongs (double-pole, double-throw)
If you already have a 3 prong one you can still wire it up just both fans wont run on high just one. I think. Here is how you could wire it with a 3 prong switch.
Old Dec 29, 2008 | 09:48 PM
  #38
isenegger's Avatar
ok thanks i get it now the fans are always hot and by completing the ground they come on. thanks alot im good with electronics i just have to be told once.
Old Dec 29, 2008 | 10:02 PM
  #39
Where did you get yor wiring from? I can prolly go to Home Depot and get 20 ga from there. I would get green and blue.
Also if the switch has 6 prongs on the back, how do you wire it up?
correct me if i am wrong.
2 wires coming eninge bay (wires that are being taped into)
2 wires from Red LED
2 wired from Green LED
What order you put the wires on the back of the switch? Got a pic>
Old Dec 29, 2008 | 10:35 PM
  #40
i got my wire from napa in town here. You wire just like said a few posts up. i don't have a pic of the back of the switch.
