Fan switch mod write-up
Old Aug 19, 2010 | 02:09 AM
  #61
99SSJarhead's Avatar
Any place with an electronic engraver can do a plate like that, you just need to given them the dimensions and lay-out. Then just drill out your holes for the switches and lights. Just google custom engraving, or heck there might even be a place in your local mall that does it.
Old Dec 18, 2010 | 03:05 AM
  #62
Reaperchild's Avatar
Okay .... im going to work with only my blue wire .... all i have to is get a 12v power source to get this to work ?? ... lets say 12v power source like the fog switch (example only) ??
Old Dec 18, 2010 | 05:20 PM
  #63
Topless TA's Avatar
SPST switch from radio shack
tap the blue wire run it to your switch,
get a black wire run it to the switch on the other pole and ground the wire.
thats it
Old Dec 18, 2010 | 07:13 PM
  #64
ULTIMATEORANGESS's Avatar
Thumbs up
that panel is top notch. nice work.
Old Jun 8, 2011 | 05:04 PM
  #65
JrodCamaro's Avatar
Bringing this great thread back to life. I picked up a switch today, but will be returning it tomorrow. They didn't have the DPDT switch, where can I get one of these from? What size amp does it need? For somebody whos done this, what did you use for a ground?
Old Jun 8, 2011 | 05:44 PM
  #66
Topless TA's Avatar
What kind of switch did you get?
Dual Pole Dual Throw DPDT switch with lights
or
Single Pole Dual Throw SPDT switch to run with no lights
my switch is s SPDT, (sub mini size)
I installed the switch just to the left of the ash tray under the cover
and grounded to one of the bolts for the shifter
I have a couple spares PM me if you want to buy one,
if you want it wired i can do that for a little extra
-J
ps http://www.radioshack.com/product/in...ductId=2062499
Old Jun 8, 2011 | 06:15 PM
  #67
JrodCamaro's Avatar
I'm guessing this goes under SPDT?
Old Jun 9, 2011 | 08:25 AM
  #68
Topless TA's Avatar
Attachment 300133
looks like it, that thing looks huge.... where are you going to mount it?
the blue and greenwires you're going to tap under the hood are only 20 gauge as i recall
Old Jun 9, 2011 | 02:50 PM
  #69
JrodCamaro's Avatar
in the process as we speak, ran into a problem. How do I connect the wires to the LED? May seem dumb but I'm unsure of the best way.. Also can I use the cig lighter ground since I'm using it for power?
Old Jun 9, 2011 | 02:57 PM
  #70
Topless TA's Avatar
With a SPDT you cannot,
with a DPDT you can
diagram to show you the connections
I would do a direct ground not the cig lighter ground and solder is the best
Old Jun 9, 2011 | 04:27 PM
  #71
JrodCamaro's Avatar
but to physically connect the wires to the LED is what I was getting at. Doesn't matter I've changed my mind on those. Can I do the connection NO LEDS, on a DPDT switch? Would it be connected the same way? just without the LED's
Old Jun 9, 2011 | 04:48 PM
  #72
Topless TA's Avatar
the first one i did was a DPDT switch, w/o led's as i recall (5yrs ago)
i had to put in a couple jumper wires to tie the DP's together for it to work
if your at all close to a raido shack, for the $5 id just get the SPDT switch
and as for the LED's
i put the led tails in the end of the wire and used solder to secure
too bad your not closer i'd help you out, but im just east of KC
Old Jun 9, 2011 | 05:08 PM
  #73
JrodCamaro's Avatar
How far east? I'll be up in KC and Olathe in about 5-6 weeks . Say I went with the SPDT switch, which wires go to which? and If I went with the DPDT no LED, what would I have to jump? I went to Radio shack earlier to get the DPDT, LED's, resistors, and connectors. After an hour and a half gave up and decided to start putting in my new MGW STS and new window motor
I figured I'll continue it tomorrow since all the hard work of running all the wires is done, almost broke my PCM thou Then decided to just do the wire thru the grommet to run it from inside to the engine bay instead of reverse MUCH!! easier
Wish I would have thought about soldering, I got a new solder gun just asking for use
Old Jun 9, 2011 | 05:29 PM
  #74
Topless TA's Avatar
Im in independence 3 miles north of i-70 and 7hwy.... if you have the green and blue tapped under the hood then you just need to attach them to the switch... check the schematic of the switch on the side.
Old Jun 9, 2011 | 05:38 PM
  #75
JrodCamaro's Avatar
Been there, might just have to meet up when I'm up that way. So the schematics will make it idiot proof? Still doesn't sound like the safest bet with me in the mix, lol. I'll see what I can figure out on my own when I pick one up tomorrow
Old Jun 9, 2011 | 05:53 PM
  #76
Topless TA's Avatar
pretty much, ask the guy at the shack and he can tell you for sure.
i got the micro with the colored vinyl cap for $4
but yea if you need help and are out my way on a saturday or sunday
we can hook it up in less than 30mins
Old Jun 9, 2011 | 06:01 PM
  #77
JrodCamaro's Avatar
Right on, probably just do the SPDT for now. DPDT if I'm up there and you have time
Old Jun 10, 2011 | 04:02 PM
  #78
JrodCamaro's Avatar
Sot this is the SPDT switch I got, no real schematics on the side. So which wires to where?
Went ahead and bought solder, so may just choose to do the DPDT, but just in case. Also, by shifter bolts, you mean the ones on your stick? Because my new MGW doesn't have any and I'll have to go a different route. Thought about doing it on my air bag sensor. Any other ideas?
Old Jun 15, 2011 | 09:54 PM
  #79
Tram's Avatar
Ok, I'm no electrician, but with a DPDT click to one side of "on" is low fans, click to the other side of "on" is high fans?
Old Jun 16, 2011 | 05:05 PM
  #80
JrodCamaro's Avatar
yes, or reverse the side with only 1 ground and you've got a "medium" fan. It will work the high fan without the low fan, I figured that out playing around with it about an hour ago.
