patriot or TSP heads?
stage 3 heads are for strokers. stage 2.5 heads are for stock displacement
LS1's. if you installed stage 3 heads in car and 2.5 heads in another car with the same cam in each car in stock displacment LS1's the car with the 2.5 heads will be quicker, even if not faster.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
stage 2.5 heads are the most for street/strip for stock displacement LS1 engine. stage 3 heads are for strokers (larger displacement LS1 engines).
