MAF sensor help, bought new MAF and STILL not working...
Like title states, i thought my old MAF sensor went bad, so i went & bought a brand new one from the dealership & I'm still not getting a reading.
I'm using HP Tuner software - Scanner to read.
I've tried spraying brake cleaner on the plug, but no luck.
Are there any joints in the wiring or anything that might be causing this problem?!
Car: 01 Ws6 M6
Car: 01 Ws6 M6
curious...does it still apply to the ls1 engines if you unplug the MAF sensor and the car runs decent its an indicator of a sensor issue?
that pushes it into open loop right...which eliminates most sensor readings.
seems like that use to work with the LT motors as a diagnosis method.
just wondering.
just wondering.
