Guys with headers, I have a quick question.
Old Dec 20, 2008 | 06:23 PM
180ls1's Avatar
Default Guys with headers, I have a quick question.
What size are the nuts or maybe bolts that connect the factory exhaust manifolds to the cats/factory y pipe? I know i need a deep socket. Thanks guys.
Old Dec 21, 2008 | 12:31 AM
ski23's Avatar
hmm,, Been a while since I pulled mine. If i had to guess id say 13 mm
Old Dec 21, 2008 | 12:42 AM
greendrazil's Avatar
Idk stick a wrench on it.
But seriously I think it was a 15mm.
Old Dec 21, 2008 | 01:29 AM
Frostbitten09's Avatar
Manifolds were a 13mm, I just did mine today with some Help....
Old Dec 21, 2008 | 01:50 AM
9000th01ss's Avatar
The socket size you need is 15mm.
Now that doesn't answer your question if you need new ones. They have a 15mm hex head, 10mm threads, but I don't know the thread pitch.
Old Dec 21, 2008 | 12:15 PM
180ls1's Avatar
so far i have two 15's and two 13's. haha. I will pick up one of each. Thanks guys for ther help. I appreciate it
Old Dec 21, 2008 | 12:47 PM
9000th01ss's Avatar
Maybe it depends on the year. Both my '01 and '02 were 15mm.
You should get 6 point sockets because they're going to be rusty and tight.
Old Dec 21, 2008 | 12:52 PM
cobrakillerta's Avatar
Originally Posted by 9000th01ss
...You should get 6 point sockets because they're going to be rusty and tight.
Ditto, I'd soak them with PB Blaster (great stuff!) for a while before you even attempt to attack those nuts. It's pretty common that they'll just snap off/break instead of actually threading off...it's actually not a bad thing
Old Dec 21, 2008 | 12:54 PM
180ls1's Avatar
ok thanks, i was going to hit them with some pb blaster to help out also.
Old Dec 21, 2008 | 01:07 PM
slowandrichws6's Avatar
all that time you spent waiting on someone to tell you what size socket it was you could have gone out to your car and just figured it out in probably 2 min at the max.
Old Dec 21, 2008 | 01:18 PM
180ls1's Avatar
well i dont have deep sockets that size because i allready tried and none fit. and i dont feel like jacking my car up and crawling under there right now to try to squeeze a wrench up there when it only takes a few seconds to post this up.
Old Dec 21, 2008 | 05:16 PM
180ls1's Avatar
ya i kinda figured that. i will spray them up good and nice first.
