LT1 radiator in LS1.. worth it?
Old Jan 8, 2009 | 01:17 PM
witry's Avatar
Default LT1 radiator in LS1.. worth it?
ok well i have a 2000 trans am A4 and live in FL so it get hot as hell here and since its cool now i want to get my car ready for the summer, i dont have the money for like a griffin or becool radiator, so that said i already have a huge external tranny cooler, lower temp fan setting 187 on 180 off (180 stat)
, i have heard that an LT1 radiator is a bit bigger than an LS1 rad. i can get a new LT1 rad for $130 but will it make a big difference or at least a difference not even worth doing it, and if it is whats involved in doing the swap.... thanks alot in advance
Old Jan 8, 2009 | 01:30 PM
the_merv's Avatar
A new Radiator in general will help. The LT1 Radiator is bigger. All you have to do is plug the connection on the bottom drivers side.
Old Jan 8, 2009 | 01:36 PM
Tainted's Avatar
the lt1 is pretty much a direct replacement. merv covered what had to be done
Old Jan 8, 2009 | 01:39 PM
Soul TKR's Avatar
I like my massive Be Cool radiator... only downside, is it's HUMONGOUS!
Old Jan 8, 2009 | 01:49 PM
Tainted's Avatar
im not gonna say a word
Old Jan 8, 2009 | 02:31 PM
Shon Herron's Avatar
That is what I am using....
Old Jan 8, 2009 | 02:40 PM
witry's Avatar
was there a noticable cooling difference from the ls1 to lt1 rad.
Old Jan 8, 2009 | 02:46 PM
Tainted's Avatar
its not as good as a becool or anything but it is a bit bigger. if you got one from a junkyard for cheap why not do it?
Old Jan 8, 2009 | 03:53 PM
witry's Avatar
i can get a brand new one for $130
Old Jan 8, 2009 | 03:59 PM
I have only used an LT1 Rad since that is what I had. biggest difference I saw was putting the stock dual fan on there rather than the 12" fan I was using...but i still have the stock thermo and it gets warm idling in the staging lanes....
Old Jan 8, 2009 | 04:01 PM
Tainted's Avatar
however pelase remember modern cars are made to runner a bit hotter. That can be tuned out by changing when your fans come on and off or with a manual switch. Your fans stock are set to start comming on at 212*
Old Jan 8, 2009 | 08:36 PM
SOMbitch's Avatar
LS1 radiator = 7/8" core. LT1 = 1" core.
Howe, Becool, SLP, LG etc... DUAL 1" core. As SoulTKR said.....HUMONGOUS
Old Jan 9, 2009 | 11:14 AM
Soul TKR's Avatar
The biggest reason I went with something other than stock, is the fact that my stock radiator failed in the first place because of the plastic on the stock radiator... what ever I upgraded to, I wanted to make sure it didn't have any more plastic anywhere on it... that **** cracks and spews coolant all over the place... if your not paying attention then bye bye engine
