SLP Header fit!
Old Jan 18, 2009 | 10:56 PM
chevguy86's Avatar
Default SLP Header fit!
Im in the middle of installing my slp lts and im on the passenger side. ive jacked the car up very high and took the starter out when i go to slide it in i get 2 of the primaries in and the flange on the last primary hits in the trans tunel . any help greatly appreciated!
Old Jan 18, 2009 | 10:57 PM
ChocoTaco369's Avatar
Tech Resident
Are these the new redesigned longtube headers or the older tuned-length headers?
Old Jan 18, 2009 | 10:59 PM
chevguy86's Avatar
The old lts i think
Old Jan 19, 2009 | 05:24 AM
04gtoBMXracer's Avatar
Took the starter off? It shouldn't be giving you that much trouble. Try lifting the car a little higher man and try a different angle. The passenger side was a lot easier than the drivers side for me.
Old Jan 19, 2009 | 05:41 AM
HMERacing's Avatar
Did you unbolt the trans mount and move it to the side like you HAVE to. Otherwise it wont go in.
Old Jan 19, 2009 | 09:57 AM
chevguy86's Avatar
Ive unbolted the starter it is hitting the trans tunnel on the end of the last flange when i unbolt the trans mount how will it give me more room cause the motor mount is still holding it
Old Jan 19, 2009 | 11:12 AM
chevguy86's Avatar
Anyone else? I need help asap!
Old Jan 19, 2009 | 11:30 AM
Arc00TA's Avatar
Can you possibly take a picture of where its hitting? I know my problem when I put my headers in was the car wasn't high enough. I ended up having to buy a 24" jack and using tall jack stands, car looked like it was doing a wheelie.
Old Jan 19, 2009 | 12:07 PM
chevguy86's Avatar
I dont have access to a camera it is the spot right where the bellhousing is I have the car up high enough to turn the headers straight up but it seems whenever i think it is gonna go in it hits that spot and wont go any farther!
Old Jan 19, 2009 | 03:36 PM
Spd-Kilz's Avatar
I went through this pain in the summer.
I ended up having to undo the bolts from the motor mounts, and jack up the engine until it wouldn't go any higher.
I also had to take a chunk out of my K-member.
Best of luck man!
Old Jan 19, 2009 | 03:47 PM
chevguy86's Avatar
It is hitting on the floorboard when the last primary goes into place. Im thinking of loosening both motor mounts and see if I can twist the motor would that work?
Old Jan 19, 2009 | 04:13 PM
Spd-Kilz's Avatar
IIRC I only undid the passenger side. How high have you jacked up the motor? Mine was almost touching (if not actually touching) the cowl.
Old Jan 19, 2009 | 04:20 PM
chevguy86's Avatar
I havent loosened the motor mounts yet i have quit for the day the header catches on the end of the k member across from where the starter is and the trans tunnel right above it I would really not like to cut my k member it seems that it just doesnt want to go in!
Old Jan 19, 2009 | 04:25 PM
Spd-Kilz's Avatar
Tomorrow, try to loosen the motor mount first. Back the bolts out almost all of the way.
If that doesn't work, then start to grind away at your K-member.
Also, just an idea before you get the in, remember that you will not be able to lower your car.
Old Jan 19, 2009 | 04:40 PM
Bad Blue WS6's Avatar
this was the only issue i ran into when installing my SLP's,,,i used the ol BFH mod on the spot where the hearder would hit,,,didnt take much to change the shape of that area to let the header squeek by...i mean like 3 or 4 hits did it. I did mine this way without messing with the starter. As mentioned, you do have to unbolt the trans mount, stick a 2x4 or whatever up there, and give a lil shove over towards the drivers side. I would do the grinding on the K member LAST, (you probably wont have to do it) I did not do anything with the motor mounts on mine...Hope everything goes well!
Old Jan 19, 2009 | 08:24 PM
HMERacing's Avatar
If you read the install directions from SLP you wouldnt even be wasting time by asking this. You would also have this project finished if you would have taken my advice instead of looking for an easy way out. dont waste time asking if you arent going to listen anyway. I have the SLP Tuned length original design headers. you have to move the transmission side to side to get them in. it is easy and you wont have to grind on ****. But if that is an option you decide to not take, Just use a ******* grinder and cut the **** out of everything until they fit.
Also hope you rerouted the pass side wires like you have to so it doesnt burn through the harness. oh well, **** it!
Old Jan 20, 2009 | 12:58 AM
Mike in LA's Avatar
You don't need to grind, just loosen up some bolts, get a ratchet strap, your favorite hammer, and go to town with it. As Mike said above "CHECK ALL THE WIRES" or you will only be able to drive 1.2 miles before the positive wire to the starter welds itself to the header. Yes I know from experience, I should've double checked the wires, I had to rerun the start wire.
Old Jan 20, 2009 | 08:44 AM
MonmouthCtyLS7's Avatar
for what SLP charges for there products you think it would be a perfect fit
Old Jan 23, 2009 | 05:33 AM
badazzt/a's Avatar
yea exactly i had the tuned length headers on my car, u figured u wouldn't have to put a lift on the car just to get around to.
