My catch can routing ok?
I'm hopin replacing all my PCV lines with fresh hose will cure my current problem as well.
also have a question about the line I have going from my brake booster to the back side of my fast intake. What should be done with that.??
Has anyone taken apart either of the brands of cc's to see what they are using for filter media? I am convinced the right type of stainless or aluminum scouring pad I am thinking of would work perfect. Lots of surfaces to collect residue and slow flow but free flowing enough so it can dribble down into the bottom.
Thanks Aaron!
My 00' Hawk didn't used very little oil before my H/C/I swap. Maybe 1/2 every 3,000 miles. I am using Mobil 1 10w30.
When I did my H/C/I/E swap I put on a Norris catch can. I hooked it up the way the instructions showed but after reading this thread I'm pretty sure it's not right. The car smokes @WOT and a little bit as soon as I let off the gas from a WOT run. It's using oil and the can is catching it. Here is what I have now. The PCV lines are still hooked up like factory on the rear of engine between the two valve covers. The only thing I did was just put the can inline on the front. I am going to change it tomorrow to the LS1 setup w/ single can pic shown earlier in the thread. This is what I have. I was looking at it tonight and noticed the PCV valve is not tight in the rubber grommet it goes in to and there is oil on the front of the intake. I assume from it blowing out.
On throttle I don't know, but I just got to witness it with my old car when I put it on the rollers.
http://www.youtube.com/watch?v=Oc1lPkaAV2c
I'm going to replace the brass fittings/hoses with black twist loc hose and fittings. I need a PCV valve to put between the can and the T/B. I know there are about 100 different kinds. I remember someone mentioning it before but I went back through the thread and couldn't find it.
Which PCV valve should I get? It would need to accept 3/8 hose on both ends. Thanks.
Added. How do PCV valves differ? Flow rate, what vacuum/PSI they operate at?
I wish I could find something like this with the correct threads, then I could screw it into the catch can and would make a clean install.
Fresh Line: Inlet port to can port attached to balve cover breathers
Outlet port from catch can attached to Intake tube
Foul Line: Inlet port to catch can attached to valley port
Outlet port from catch can attached to TB
I simply put the can (in line) with the existing fresh and foul lines, per Mr. Seranno's advice
Here is a recent pic with the new tvs2300. I just routed it the same way.
Once I get the tranny addressed and my torque converter next week , I will see what she will do at the track vs the 1900.
Is this diagram the same with or without the breather on the oil cap? Is the breather really necessary on my H/C/I car? I really don't care for the look on a 4th gen, the 5th gen looks ok because it's recessed in the engine cover.
Also, is the "side of the catch can" in the diagram the outlet? Both fittings are on the top of the Rx can
Instead of saying it SUCKS, just address your question in a manner so that someone is going to be more willing to help.
I'd be more than happy to help you with how to properly route it. Email pics of the back area of your drivers side valve cover, passenger side valve cover and your valley cover if you can. If not, just explain it as best as you can in an email. We have PDFs of several routing diagrams we can email over that will probably cover your H/C setup.
I posted the diagram above because that's the setup I currently have. I'm running the stock PCV system with the LS1 valley cover, I bought the car brand new and have not changed it. Just confused because I've got 2 schools of thought here.
Sent you an E-mail.
This is how I have mine setup. then I used the home depot ( I allready had) as a secondary kindof like a proof CC.
I'm using the pcv stock location before the double chambered CC, then the HD.
works great.
Badmfkr
