My catch can routing ok?
Still scan for code to be 100% sure what's going on.
No breather cap BTW. Am I running the right setup?
I am doing this to a 3400 in my monte and building everything from scratch, i was able to use kitchen sink SS braided lines. I'm in the procewss of re-routing everything, but this is how wrong i had it:
Please no one get confused, this is the WRONG WAY lol
I tried using a PCV valve from a late model Chrysler on my car. Ever since then the bottom of the oil cap looks like a milkshake. I have put several hundred miles on it in a week or so. I figured that would be enough for the moisture to be burned off.
You've both got it backwards.
I attached how it should be routed(I have the LS6 valley cover though) so the side line is from the crank, and the top line goes to the intake, plus a sweet paint drawing of the inside of the catch can.
Where is your pcv? Mine is hooked up exactly like the diagram for a ls6 valley cover with pcv valve earlier in this post.
I believe you have it backwards.
I think so.
With this particular can (you have this one too right, along with another?) I want the oil to come in the side and go to the bottom so when its being sucked up from the top through the filters its going to be much more difficult to get oil though there. Other wise going from the top the oil just goes though the filters from gravity, drips to the bottom and then can be sucked up (in vapor form) through the side with nothing stopping it.
Ive been running it this way for a long time and its catching plenty of oil and getting little to no oil in the intake.
I know other catch cans will be routed differently depending on where the filters are and how its setup.
I think so.
I had it this way, intake was full of oil.
I think so.
