My catch can routing ok?
Ok I just looked at the Norris webpage and it looks like Im wrong, they have it setup like you (although I swear I've seen it hooked up like mine). But doesn't my logic about it sound right though?
Been fighting a rear main area leak for a while now, I think this is what was doing it.
If you pull the PCV valve hose off the can with the engine running and put your thumb over the hose, the pcv valve clicks like it should now.
The throttlebody actually had oil puddled in it, intake runners were really wet.
EDIT
I had to change water pump gaskets this past Saturday, the throttle body is now dry and the intake just has a leftover film in it. Rear main is area is now dry.
The can had a good bit of oil in it since I swapped it around.
I opened the can up and looked inside, it has a deal sticking down lower than the side inlet. So the oil comes into the side from the LS6 valley cover and hits this parts and falls to the bottom.
Has a filter screen in it where the top exit is.
So I feel I have it right now.
From my understanding I can Tee both covers to the top port catchcan and the bottom port goes between the TB and blower (no checkvalve needed with PD blower).
Is this where it gets is fresh air source from? What about PCV valve, I know its basically like a checkvalve, where does it go, do I need one?
I see some people saying they've done the LS6 valley cover and everything is now dry. If that's the case, what would the point of the catch can be? Why not just spend <$100 for the LS6 conversion and be done?
BTW Gm makes plugs for the drivers side valve cover to close the hole in the valve cover.
See, I already have the plug on the Drivers' side that you mentioned. With the plug on the Drivers' side, the Drivers' side valve cover is not venting, correct? So why is it necessary that the passenger side valve cover vents if my catch can is routed from the LS6 valley cover to the intake with a truck PCV valve?
I'll hook it up if I have to, but I really don't want to if the venting from the valley cover is enough...
Your PCV is not working, for it to work it has to pull air through the engine, as it is now it cant because the other end of the straw(passenger valve cover) is blocked off.
I'll hook it back up this evening, thanks again for the replies
I've been a way from the forum for a while so bare with me.
Most questions everyone keeps asking have been answered numerous times already, so its definitely worth reading the entire thread.
Diagrams were very helpful thank you!!!!!
