My catch can routing ok?
Can you post more pictures with a broader view of the install? To confirm, you have a single port on the passenger valve cover (front) and one port on the driver valve cover (rear)? What is the clean side routing?
I worked in parts for about 8 years, and as I recall, there were a million different PCV valves available behind the counter. Is there a certain vehicle to reference when picking up a PCV? I ask because I can't remember if the tube diameter was fairly universal for the majority of vehicles or if they varied... or if it even matters. Also, what exactly is a "vacuum cap?" Just a plastic cap?... or is it some kind of crazy NASA designed cap available only from nuclear submarine junkyards? Sorry for the ignorance.
I actually started the long trek across this thread to finally get an "end all" answer on which catch cans actually work. I'm happy to say that this is no longer a mystery!
Thanks again for the awesome info and diagrams Aaron!
I use the stock PCV valve with the stock PCV 'boot'. Most of the PCV applications for V8 cars have a 3/8" or 11/32" hose ID. A vacuum cap us just a simple rubber cap used to block a vacuum port.
Also, I think there are a million and one different PCV valves.
First off... KILLER THREAD!!! 405HP_Z06 you have went a LONG way out of your way to make every ones crap work right...
I've tried three different pcv set-ups with my truck and came across this thread. I plan on routing mine like your twin catch can set-up. BUT I'm a broke ***** and I like building crap myself. SO,,, What do you think of these catch cans???
<snip images>
